Steering wheel column lock picture or diagram
14523 Views 4 Replies 3 Participants Last post by  vms4evr
Does anyone have an actual picture of the lock pin or lock mechanisim that keeps the steering wheel from moving when the key is not turned?
Is this some thing that is directly inside the ignition lock cylinder case? Im looking to do a keyless setup and have found that this will be my only real hurdle from making it a complete keyless push button system.
I've found that the C5/C6 has bypass boxes but the CTS/CtsV is not an electronic lock I beleive. The alldata info is a little vauge, and doesnt say anything in regards to the actual lock mechanisim itself.
Thanks!
Can anyone confirm this is the pin, spring, and lock plate?
Item 10 = Turn Signal Cancel Cam; Item 18 = Spring Guide; Item 19 = Tilt Spring.
1 - Upper Trim Cover
2 - Lower Trim Cover
3 - Steering Column. Closeout Trim
4 - Flange Prevail Torque Nut
5 - Retaining Ring
6 - SIR Coil
7 - Wave Washer
8 - Bearing Retainer
9 - Cam Orientation Plate
10 - Turn Signal Cancel Cam
11 - Upper Bearing Spring
12 - Upper Bearing Inner Race
13 - Inner Race
14 - Switch Mounting Bracket
15 - Turn Signal and Multifunction Switch Assembly
16 - Steering Column-Tilt Head Assembly
17 - Wire Strap
18 - Spring Guide
19 - Tilt Spring
20 - Release Lever Pin
21 - Pan Head Tapping Screws
22 - Wire Straps
23 - Pan Head Tapping Screws
24 - Window Washer and Wiper Switch Assembly
25 - Wire Straps
26 - Theft Deterrent
27 - Ignition Lock Cylinder Case
28 - Race and Upper Shaft
29 - Centering Sphere
30 - Joint Preload Spring
31 - Lower Steering Shaft
32 - Pivot Pins
33 - Wire Strap
34 - Steering Column Jacket Assembly
35 - Steering Column Position Sensor
36 - Sensor Clip
37 - Sensor Seal
38 - Boot
39 - Bolt Retainer
40 - Pinch Bolt
41 - Intermediate Shaft Assembly
I'm not sure if you can't just install the C5 bypass kit. I installed this on my 02 Z06 and have never had the lock problem. My previous 02 Z06 did it but I got it to free up. Then immediately installed the bypass. The GM answer is to let the dealer actually pull the shim/pin out of the steering column so it can't lock even if the signal in the lock system says to hold it. That was done under recall quite often.
http://www.corvettemods.com/product.asp?itemid=6373&gclid=CMeAtvLRxsUCFYwXHwodb54AVw
This is the kit I used. Simple and works fine. I haven't heard of this issue with the V though.
