If I put the ignition in accessory mode I get the above warning within only several minutes. I have dual batteries and when checked they were both fully charged. So...is this warning set to display by a timer and not actual battery voltage?
Hello crusher,If I put the ignition in accessory mode I get the above warning within only several minutes. I have dual batteries and when checked they were both fully charged. So...is this warning set to display by a timer and not actual battery voltage?
Same here. Within 3-5 minutes I will get the message as well and it always starts without fail.So I'm guessing this is not normal given the 349 views. I left the switch in the aux. mode and played the radio for 3 hours but it started up with no problem. Warning came up in under 3 minutes. Guess it is a timer thing not actually reading the battery or in my case batteries.
I have the same problem can someone answer this questionSame here, comes up within a few seconds, everything was turned off, yet it still comes on pretty quick. I had 2 dealers test it and both said the battery is in good shape, so I donno...
Go for a battery test at your favorite Auto Parts store. Might need some more electrons.I have the same problem can someone answer this question
