2004 Seville SLS
I have just finished reinstalling the engine in a 98 Seville STS and want to start an run it to check for leaks and top off fluids. Can I do this without hooking the air bags up again?
sure - why not?
and pull the SIR fuse under the back seat -
2004 Seville SLS
I didn't know if there is some sort of electrical interlock that would prevent it from starting if they are
disabled. Fuse was first thinks I removed after the back seat.
What part of removing the engine necessitated disconnecting the airbags? :hmm:
He probably meant just disabling the airbag system. I believe it's on the service manual to disable airbags before any repair.
2004 Seville SLS
Because the FSR said to disconnect them and remove the fuse under the back seat.
Because the FSM said to disconnect them and remove the fuse under the back seat.
Because the FSM said to and to remove the fuse under the back seat.
