Hello all, I have a 93 Seville that has a 4.9, it runs fine until I turn a corner and then she sputters and tries to stall, any ideas? In advance Thank you!
Tom
Tom
I've read the same problem from others and the concensus is that there was a design problem in the gas tank that shows up while turning when the fuel level is pretty low. There are baffles in the tank and under the right(or wrong) circumstances they keep the fuel from getting to the inlet. The fix is to buy the redesigned tank, which is pretty costly, or to make sure your level doesn't get too low, which is more or less free. Keep it over a half tank and you'll have no problem if that's the cause of your stumble. I hope it's that easy in your case, it seems to be fairly common.
Bob
2005 CTS-V, 1994 Infiniti Q45
Bob is absolutely right, very common!!!!
