1 - 8 of 8 Posts
on my escalalade 2007 the stabilitrak light is coming asap i drive downhill on normal street, any hints ?? could be any fluid level low ?? there are no error codes detectec by the predator...
thanks robert from germany
2012 Escalade, 2014 SRX
Welcome to the Forum :) Where are you in Germany? Fluid is not an issue with stabiltrak. Is your truck stock? Do you have aftermarket wheels and tires? Suspension lowered?
i´m from Ingolstadt, 60 miles north from munich, Everything is stock on my 07 escalde with only 6000 miles
I lived in Switzerland for 3 years in Biel and outside Baden, and spent a lot of time in Germany. :) There could be many things causing your problem, has the truck been on a lift or anything? You will need to find someone with a Tech II tool.
Truck was on an lift for installing LPG system&tank.. what was your intention with the lift/stabilitrak issue ??
greetings robert
1 - 8 of 8 Posts
