1 - 9 of 9 Posts
2014 xts
Hello folks,
Good day to you - hope God is good to you.
Okay, driving to Florida, poof:
~ Stability light display across the alert system.
~ Stability function button to the dashboard right does not work
~ T/C idiot light on, stability idiot light on and cruise control not working
~ turn car off, restart and idiot lights off yet function of all three not working.
what say you. A fuse? Or buy a new car? Thank you. (2014 XTS)
Pilager
XTS
For me, it was a cylinder misfire, many functions were not working but i kept driving it for more than a year, finally I replaced the engine ( cheaper than to fix a cylinder )!
Other functions will not work such as remote start, driving was fine other than when I stop the engine it started to shake slowly, this increased by time until it became uncomfortable then I decided to fix it,
hope it's not the case with you,
good luck.
Missfire is either a coil or spark plug. Did you run a compression test to see if you have bad rings or valvesxnot sealing properly? It's not really a reason to replace an engine.
'02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
I doubt someone is going to do a compression test when the two options they suggest for troubleshooting are fuse or vehicle replacement.
14 XTS Premium, 16 Lincoln MKC Reserve AWD, 14 VW CC Executive
Hub bearing gone bad, either front or rear. Get it replaced before it goes into reduced power mode. Happened to me twice already. Exact same alarms.
1 - 9 of 9 Posts
