According to the VIN you supplied, I found this for a 2005 SRX
http://www.gmforum.com/vindecoder.php?vin=1GYDE637550137550
General Information
MFR model code 6EB26
Body type: Sport Utility
Pass Doors: 4
Alternative name:
Alternative body: Sport Utility
Drivetrain: Rear Wheel Drive
Original Pricing
MSRP $38,340.00
Invoice $35,464.50
Destination Charge $695.00
Engine & Powertrain
Type V6 Cylinder Engine
Displacement L/CI 3.6/217
Fuel Type Gasoline Fuel
Horsepower 255.0 @ 6500
Fuel Economy 16.0 City / 22.0 Highway MPG
Fuel Capacity 20.0 gal
Net Torque 252.0 @ 2800
Tech Specs
Manufactured By United States Cadillac MPV
Curb Weight - Front 2160, 2082 lbs 2082.0 min 2160.0 max
Curb Weight - Rear 2160, 2082 lbs 2082.0 min 2160.0 max
Suspension Type - Front Independent
Suspension Type - Rear Independent
Front Tire Size P235/60VR18, P235/65HR17
Rear Tire Size P255/55VR18, P255/60HR17
Brake ABS System 4-Wheel
Front Brake Rotor Diam x Thickness 12.7 x 1.26 in
Rear Brake Rotor Diam x Thickness 12.6 x 1.02 in
Wheelbase 116.4 in 116.4 min 116.4 max
Ground Clearance, Front 8.2 in 8.2 min 8.2 max
Ground Clearance, Rear 8.2 in 8.2 min 8.2 max
Mechanical & Powertrain
Engine, 3.6L V6 VVT (255 HP [190.2 kW] @ 6500 rpm, 252 lb-ft [340.2 N-m] @ 2800 rpm)
Battery, Delco maintenance free, includes rundown protection
Suspension, 4-wheel independent
Steering, power, rack-and-pinion, speed-sensitive
Fuel capacity, approximate, 20 gallon (76 liters)
Exhaust, stainless-steel with dual stainless steel tips
Safety
Air bags, frontal, dual stage and side thorax for driver and front passenger, head curtain for 1st and outboard 2nd row passengers (Head curtain air bags are designed to help reduce the risk of head and neck injuries to front and rear seat occupants on the near side of certain side-impact collisions. Always use safety belts and proper child restraints, even in vehicles equipped with air bags. Children are safer when properly secured in a rear seat. See the Owner's Manual for more safety information.)
Safety belts, 3-point, all positions
Door locks, child security, rear
Interior
Seat adjuster, recliner, manual, passenger
Armrest, center, front
Armrest, center, rear, includes dual cupholders
Console, floor, includes floor shifter, integral armrest, storage compartment and cupholders
Floormats, carpeted, front and rear
Steering column, Tilt-wheel, adjustable
Steering wheel, mounted controls, includes controls for sound system, and HVAC system
Instrumentation, analog, includes speedometer, tachometer and fuel gauge
Fuel gauge, analog
Windows, power, includes all express-down, front express-up and rear passenger lockout
Cruise control, electronic with set and resume speed, includes telltale in instrument panel cluster
Theft-deterrent alarm system
Theft-deterrent system, PASS-Key III
Defogger, rear-window, electric, includes front and side window outlets, driver and front passenger
Sound system feature, 7 speakers, includes dual speakers in windshield pillars, front and rear doors and instrument panel
Antenna, integral, front and rear
Visors, illuminated vanity mirrors, driver and front passenger
Convenience net, rear
Cargo cover
Exterior
Roof rails
Headlamps, halogen, Tungsten, windshield wiper activated, includes Twilight Sentinel and flash-to-pass feature
Fog lamps, front, integral in front fascia
Glass, Solar-Ray deep tinted, mid-rear-side and liftgate
Rear Park Assist, Ultrasonic, includes rearview LED display and audible warning
Interior ColorsCode
Ebony
19
Light Gray
13
Light Neutral
70
and this from
https://recalls.gm.ca/#/?vin=1GYDE637550137550
Safety & Non-Compliance Recalls
What's this?
GM Recall #:
N140172
Date Issued:
2-Jul-2014
Recall Title:
UNINTENDED IGNITION KEY ROTATION
Recall Description:
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 2003-2014 MY Cadillac CTS and 2004-2006 MY Cadillac SRX vehicles. If the key ring is carrying added weight and the vehicle goes off road or experiences some other jarring event, or if the driver unintentionally bumps the key ring or items attached to the key ring with their knee, the key may unintentionally move away from the "run" position. If this occurs, engine power, power steering and power braking may be affected, increasing the risk of a crash.
Safety Risk Description:
The timing of the key movement out of the "run" position, relative to the activation of the sensing algorithm of the crash event, may result in the airbags not deploying, increasing the potential for occupant injury in certain kinds of crashes. Customers should remove all items from their key rings, including the key fob, leaving only the ignition key. In addition it is very important that drivers adjust their seat and steering column to allow clearance between their knee and the ignition key.
Repair Description:
Dealers are to install two key rings and an insert in the key slot or a cover over the key head on all ignition keys, free of charge. Until the recall has been
Recall Status: INCOMPLETE
Other Programs for Your Vehicle
What's this?
GM Program #:
N050524
Date Issued:
16-Feb-2005
Program Title:
ECM EEPROM EXCESSIVE WRITES - REPROGRAM ECM
Program Status: INCOMPLETE
