If you are talking about the actual motor that raises/lowers the liftgate, it's not that difficult. Remove the drivers side panel in the rear and you will have pretty good access. If you are talking about the lift gate actuator in the hatch that releases the hatch, then that is more complex and you will have to remove the liftgate panel and can be challenging but will take you a good 1-2 hours. I've done both.
