Yup. Either the RCDLR (remote control door lock module) has gone bad, or power isn't getting to it. FYI the module is mounted to the inside of the big interior panel in the back on the passenger side. It's a little black box about 1in x 3in x 4in, and if necessary a replacement module can be had on ebay for like $25. If the fuse is good, that is the next thing to look at. If there's 12V at the red wire at the module, the module is the problem. If not, then a fuse or a wire someplace between that and the rear left fusebox is the issue.
I had the same exact problem on my 2007. A water intrusion issue (probably from the moonroof drain) had gotten the RCDLR wet repeatedly and ruined it. Replacement wasn't hard, no reprogramming or anything needed, and the tire pressure monitor system and remote lock/unlock and power rear hatch all worked perfectly as soon as I replaced the bad module.
