1996 cadillac deville 2007 DTS Luxery 1.
Hi everybody , my 2007 dts , vin-1g6kd57yx7u153206 , fe1 suspension , has an intermittent "clonk" sound over bumps. Also it gets that 'squeek' sound at times , mainly when I hit my brakes. I have replaced front struts (Monroe quick strut) , stabilizer bar bushings (gm parts) and stab end links (gm parts). I do believe I need 2 inner tie rods , but I don't know if they have anything to do with the noise problems. I am leaning toward the control arms ????? Any Help ???? (this is front suspension)… Thank You , Tim
This may sound really stupid: Check your caliper mounting bolts. I have seen one bolt snapped off before, and the car stopped fine. That said..... broken strut spring/mount/ etc Most of the time, a fwd cady will have serious torque steer under heavy acceleration long before the a-arm bushings start clunking. They do squeek long before steering or tire wear becomes an issue.
2006 DTS perf
2006 DTS Performance Lux III
happened to my DTS. Left front caliper mounting bolts loosened up. Made a loud rattle like the strut was about to fall off.
After driving around tonight , I noticed I get that "clonk" sound much more when braking over bumps in the road. I also notice if I am making a turn (without brakes applied) , I will get the "clonk" sound if bumps in the road. Any more suggestions ??? Thank You Johnny G D and Omac for the info. Caliper mounting bolts are tight.
