I just started driving my 94 Deville 4.9L again. It has been sitting for a little while. Everything works and drives great however there is a terrible high pitched squeal coming from the drivers side rear wheel.
It happens only when the car is moving from 2 mph up to 70 mph. It doesn't go away or get worse with braking. The only time it will go away is when you are slightly turning left. Then it goes away but comes right back when you straighten up.
It is only from this wheel and like I said the car has to be moving.
What do you guys think? Wheel bearing? If so can the bearings just be replaced or does it need a new hub? Thanks.
2010 DTS
Brake wear indicator. It's just a bent piece of sheet metal that scrapes the rotor when the pads wear down to a certain point to get your attention.
