check the fuze...
I just checked almost all my fuses and couldnt find any bad ones. I didnt see a fuse labeled "sport" in the diagram. Do you know which one it would be?check the fuze...
I dont notice any diffrence when I push the buttonCan you tell if the car is going into sport mode or not?
my 05 in sport mode or not when you floor it, it supposed to shift at the same point. sport mode is just to hold the gear longer when you release the gas pedal so it wont upshift to help gain back power when you accelerate again thats it.Simple test to see if it is in Sport mode ... from a dead stop ... floor it! First shift should be just shy of 7k in Sport mode. Less than that and it is not in Sport mode. Doubt it is a problem with the indicator light ... I designed the PCB for that cluster ... it's an LED and changes it went bad are next to nil. My bet is something is wrong with TC or Stability preventing it from being turned on. Pop a Tech2 on it and see what codes are thrown (or have the dealer scan the codes).
That's not how mine works at all! Shift points are higher ... BTW ... that's what longer is ... upshifting at higher RPM! It also eliminates overdrive and never shifts into it.my 05 in sport mode or not when you floor it, it supposed to shift at the same point. sport mode is just to hold the gear longer when you release the gas pedal so it wont upshift to help gain back power when you accelerate again thats it.
Try on the highway at 65 mph. Push the Sport button. The car downshift one gear. Hold that speed for approx one minute and its back on overdrive.That's not how mine works at all! Shift points are higher ... BTW ... that's what longer is ... upshifting at higher RPM! It also eliminates overdrive and never shifts into it.
Thats not what the manual says, but its what my car does. According to the manual, the car will shift at higher rpms when in Sport Mode. But from experience with a couple CTS' now, the car will redline in Sport or normal.my 05 in sport mode or not when you floor it, it supposed to shift at the same point. sport mode is just to hold the gear longer when you release the gas pedal so it wont upshift to help gain back power when you accelerate again thats it.
It should be by your gear selector, but I don't believe that all of the CTS's came with it.i never knew aboout this switch? wheres it located? what CTS does it come with?
