1 - 9 of 9 Posts
Can anyone tell me or load pics of the location of the speed sensor? I'd like to replace it myself....if I can find it.
Peter B.
2001 Catera
Cadillac Technician
none
Which speed sensor?
Why?
There are several speed sensors, perhaps you are referring to the "vehicle speed sensor"?
If so I can only assume your speedometer quit?
If the above are true, replacing the sensor will probably not fix your problem.
Please elaborate.
Yea, the speedometer often reads 0. I checked the code and its a P0500 - speed sensor malfunction. Any ideas?? Thanks, Pete
Cadillac Technician
none
Usually on Catera when the speedo drops to zero you'll see a couple lights come on as well.
The vehicle speed comes from the right rear wheel speed sensor via the EBCM to the TCM.
If the ABS light comes on also, and you see transmission codes and ECM codes... you probably need an EBCM.
There are several posts on this concern on the forum.
Bummer that doesn't sound good. What's a ECBM?? Yep when the speedo drops to zero the ABS, traction and engine light come on. Thanks.
Peter B.
Cadillac Technician
none
The EBCM is the Electronic Brake Control Module.
It is located just in front of your brake master cylinder and below.
It is attached to the ABS unit.
A factory repair part can cost about $1,300 plus installation.
I usually charge about 3 hours.
I have heard of places that will refurbish yours or sell you a rebuilt one in exchange for your old core.
I saw that mentioned on here somewhere.
You might ask around and see what kind of luck people have been having with them.
It sounds like that is what is happening to your car.
ZenButcher! AKA Peter B.
Yes - I contest - it's more than likely the EBTCM Electronic Brake Traction Control Module...
I have a 1998 catera and had just about the same issue(s): the speedo & odo failed to work and the ABS & TC & ENGINE CHECK lights were ON; but the car drove as normal. But get it fixed ASAP - dont drive it "as is" - you dont want to welcome other problems RIGHT!
A local WI dealership wanted $1500 for a new EBTCM + labor = say $2000 total! I told them to lay-off the crack pipe... I had mine pulled, fixed and installed for under $500! It's a bear to pull so have a [quality/qualified] mechanic do it. I even paid for over-night delivery and personally sent my EBTCM to:
http://modulemaster.com/index.html
it will cost only $200
*SERIOULSY! HAVE YOUR ORIGINAL REBUILT - DO NOT DO AN EXCHANGE OK!
Make sure you write the serial# and any associated numbers on the EBTCM before shipping so as to get the original back. ModuleMaster will replace a switch inside the EBTCM and you will pay for the return shipping as well.
Note: Have it shipped to the shop that pulled the unit and they'll install it straight-away. I paid for 2 hours of labor $65 per hour.
Enz
Discussion Starter #9
Excellent help guys! I took to my shop and went the rebuilt route. Even they b!tched about the design of it. But a total bill of $310 - I'm happy. Speedo works, no dash lights, I'm in Catera heaven. One things for sure, I was lucky I didn't get a speeding ticket while driving with no speedo.
Thanks again,
Peter B.
'01 Catera
1 - 9 of 9 Posts
