1 - 14 of 14 Posts
CTS-V
Hi.
First post over here on the STS board. My father drives a new 2005 STS and the day after he got it, a warning light came on that said that speed would be limited to 80MPH. The dealer did something and it was okay for a couple of weeks, but then it came back. It's really problematic (not that he's a speed demon). Nonetheless, the dealer cannot fix it. A GM rep is supposed to weigh in tomorrow to determine if they'll buy the car back from him. He likes the car, so its disappointing that the dealer cannot fix it. Anyone ever hear of this issue?
CTS-V
The dealer and GM are supposed to decide soon what they are going to do. I don't see how they can choose not to buy it back, but what GM does and doesn't do is not always the path that seems to make the most sense.
2008 STS V8 RWD 1SG+Perf Coll. + Perf Handlin pkg
The 2005 STS Owner Manual says the following:
:bomb: SPEED LIMITED TO XXX
This message will display when your vehicle speed is
limited to XXX (mph in English mode and km/h in Metric
mode) because the vehicle detects a problem in the
suspension system. Have your vehicle serviced by your
GM dealer.:bomb:
I suppose that this can mean a faulty sensor or a faulty suspensions system.
Mine does it at the 121 MPH mark (which is reasonable) but at the 80MPH mark, wow, that sucks.
I hope they can get that fixed! Not just because of the speed (its illegal to hit that speed in just about every road in the country anyways) but because who knows that other problems that can lead to (having a bad suspension).
Good luck!
soupero said:
@psykiv
I think the car is made for the top speeds of 250km/h so it shouldn't break down or something at that speed
Exactly. So if the sensors on the car are going crazy at half that speed (80mph or 129kph) then there is definitely something wrong.
The only time something would go off at those speeds for me is if I made a sudden and quick shift in directions (like switching lanes quickly) or if i just hit a big pothole or something, even then it only says traction control or stability system, not electroncially limited.
· Cadillac Technician
none
If that light comes on it must be setting a code. Is there documentation of any trouble codes on your copy of the repair order?
None
cz3826 said:
Mark,
Where did you get the STS side scripts??
cz3826.........05 STS
They're CTS Side scripts, but i'm sure you could get some STS ones. I ordered them from the dealer, about 9 bucks I think, self adhesive 3m tape on the back. Just tell the dealer you want to order a couple of the rear trunk STS emblems (the one on the right)
I don't know how it would look on the STS though, don't you guys have a turn signal placed there on the fender?
1 - 14 of 14 Posts
