Re: spare rim/tire won't fit....WTF
Did you take the tub part and the insulation out?
:histeric:Guess its just too fat for the hole.... I have that problem a lot.
T
I'm glad I have a junker for a spare, and don't care about it, as it has really gotten scratched up due to:I ordered a spare from here, and it only fit outside down. I don't have the jack yet, but Caddy service can take care of that. So it will scratch? Maybe I'm just really weak, but it was heavy and cumbersome to get in the hole. (Being serious, all the pervs- cut it back.)
Tell the guy to relax... just kidding... had to say it.Guess its just too fat for the hole.... I have that problem a lot.
T
LOL!Tell the guy to relax... just kidding... had to say it.
Damn, I wish someone had mentioned this before I bought a spare with a GS-D3 mounted. With the wheel facedown (no padding underneath) I can't even get the lockdown nut on, and I'm nearly an inch over the floor. Useless. Oh, and why do folks keep asking if you took the tub out. On my '05 at least, the tub is divided, so you can't fit a full size spare in there without removing it, making that question moot.I have a 245/45/18 GSD3 in there, and it's about as you describe, although I can turn it down about 10 turns. It definately sticks up about 1/4".
As a side note, I have a trash rim, on which my spare is mounted, so I have the 'outside' of the rim farcing down, as I don't care about the finish. Do you have your's facing up?
Botom line is either:
1) Find an 8" mille miglia, and get a 225 tire
2) switch back to RF's
3) Live with the small gap
-Chris
The GS-D3 has unusually wide shoulders. A worn F1 or some cheapy touring tire will do just fine. It's a spare, so just get some rubber on that rim and you'll be fine. In fact, getting a 235 or 225 tire may even be cheaper and will fit even better. The rim is narrow enough.Damn, I wish someone had mentioned this before I bought a spare with a GS-D3 mounted. With the wheel facedown (no padding underneath) I can't even get the lockdown nut on, and I'm nearly an inch over the floor. Useless. Oh, and why do folks keep asking if you took the tub out. On my '05 at least, the tub is divided, so you can't fit a full size spare in there without removing it, making that question moot.
Now you're saying use a narrower mille maglia wheel as a spare. Those were like $120 at Tire Rack when they discontinued selling them.
How about changing the FAQ to reflect that certain stock size tires have no chance of fitting in the tire well. To not be able to put the cover back on (flush with the trunk floor) kills the whole idea of an onboard spare.
I wonder if you can deflate a GS-D3 to get it to sqeeze down under the cover, and then carry a cigarette lighter inflater if you ever need the spare.
Brian R.
As an FYI, I have a 2/3rds worn GSD3 (245/45R18) in my spare tire well on the junker rim, and it fits. Barely, but it fits.Damn, I wish someone had mentioned this before I bought a spare with a GS-D3 mounted. With the wheel facedown (no padding underneath) I can't even get the lockdown nut on, and I'm nearly an inch over the floor. Useless. Oh, and why do folks keep asking if you took the tub out. On my '05 at least, the tub is divided, so you can't fit a full size spare in there without removing it, making that question moot.
Brian R.
Thanks, I thought that was probably the case. I'll try letting out some pressure and seeing if I can squeeze it down. I can't remember the exact language used in the FAQ, but perhaps it should be amended to emphasize a narrow shouldered tire for use as in the spare well vs. a well worn tire. Diameter wise, it seems there is tons of spare room.The GS-D3 has unusually wide shoulders. A worn F1 or some cheapy touring tire will do just fine. It's a spare, so just get some rubber on that rim and you'll be fine. In fact, getting a 235 or 225 tire may even be cheaper and will fit even better. The rim is narrow enough.
