1 - 8 of 8 Posts
1997 Deville
Have a 1997 deville when I start the car it sounds like a bearing is racking around near the water pump,any ideas of the correct part I need o replace I have fixed water pump and idler arm pulley tensioner and pulley
2010 DTS
Re: Sounds like a bearing loose
The WP & tensioner pulley are recently replaced? :hmm: There is nothing else in that area to make that kind of noise.
Where did you get them from?
1997 Deville
Well yes I replaced the water pump brand new got it online ac delco, and the accessory belt tensioner was just the piece that has thereby belt on opposite side of power steering, actually I am so sorry I meant bearing sounds loose on power steering pump side im so sorry
2010 DTS
Ahh, in that case, maybe it's the P/S pump. Have you checked the fluid level.
Yeah, that ^^^^^^^ - and in a 1997, it might be the serpentine belt tensioner pulley or an idler pulley - or the A/C clutch center bearing.
1997 Deville
Discussion Starter · #6 ·
Yes cuz the power steering is brand new I figured it was the tensioner bearing or idler arm but wanted to see what u thought before I go replacing all, thanks so the idler arm itself or the pulley I have a feeling it's rhat
www.rockauto.com, your make, year, model, "belt drive", two types: small 3-rib water pump belt tensioner/pulley, larger flat serpentine belt tensioner pulley/arm.
1 - 8 of 8 Posts
