something drain the battery
when I disconnect ground and touch the ground,,,big sparks appears
removed the blower fuse and disconnected the blower controler.
maybe its because I have a water leak passenger floor.
I looked to fond the leak but no luck.
what drain the battery ?
Thanks to help me
Premium Member
Regulator or bad diodes in the alternator. Disconnect the big wire on the alternator and try your test again. Do not let the alternator wire touch ground
Thanks to help me
It could be a number things that cause the parasitic battery drain, however the alternator in our model is the most common issue usual due to a bad rectifier or voltage regulator which usually means a new alternator anyway.
I had the same battery drain issue and it was the alternator, however since you have a water leak the issue could be from shorted electronics.
