1 - 2 of 2 Posts
Just had the front brake pads replaced..
And since have noticed that the front of the car...kinda "noise dives" upon braking...Is there an adjustment to the rear brakes that should be made...or a simple fix..that I'm overlooking. The brake fluid system was n=ever opened...so i doubt its air...and they dont "pump up"...The pedal just seems a little low to the floor. The back brakes look as though they were recently replaced as well...
Any feedback appreciated
Thx
Adaddo
Other than checking the system to make sure all brakes are working......there's not much to do. 4-wheel disc brakes have no adjustments to equalize the front/rear balance. If all components are working properly and the car still seems heavily front brake biased, you might want to check your suspension for a problem.
1 - 2 of 2 Posts
