2004 SLS
My 97 STS stopped blowing air from the front vents. That is, the blower fan and/or fans do not work for the HVAC. The rear passenger vent blows air(only at highest fan speed)....strange, because I can get heat from it.
Any suggestions would be greatly appreciated. Thanks in advance.
2004 SLS
The problem re-occurred 3x since. At all times, I was able to get the blower working once again, by popping open the hood, and wiggling the connector. Since the weather has let up today, I inspected the connector further.
Upon closer inspection, I found the two outside pins(female) on connector were much looser than that of the center pin. That is, they had a wider opening becuse the receptor tabs were bent further out/opened up more. Possibly preventing the male pins (on motor) not to make full contact within.
I sprayed the pins with WD40. Inspected and cleaned for any deposits. Took a very thin nail, and bent tabs to close gaps. Pronto!
