I have a problem with my 1998 cadillac SLS.
I got the "check brake fluid" message on my dash, along with the brake warning light and traction control light coming on.
I checked the level, it was just below MAX.
I also unplug the connector, jumper the 2 leads, then start the car.
Unfortunately, the warning remains on the dashboard
Current Codes:
No ABS DATA
IPC U1255 Current
PCM P1602 Current
I think it has something to do with ABS.
Searching the forum I have found that it could be the EBTCM, Ignition Switch, Loose Battery Connections or faulty sensors/wiring.
I have already checked the fuses and replaced the EBTCM and Ignition Switch.
Does anyone know the solution to this problem?
Current Codes:
No ABS DATA
IPC U1255 Current
PCM P1602 Current
