Hi guys,
Short introduction: my name is Otto, 26 yo from The Netherlands and since a month ago the proud owner of a Seville SLS from 1997. Lived in the States a couple of years and always had a thing for American cars. Promised myself my first car would be an American. Kept my promise
She's a beauty and drives so smooth! However, I do have a couple of problems. I hope you guys can help me out.
Notes: - I don't have a fusebox for the maxi-fuses (driver-side next to the engine). Previous owner put a rubber mat over it. Looking for a new one.
- It's winter here (cold and wet). Maybe the fuses get moist?
* First of all sometimes she won't start (warm or cold engine, doesn't matter). I'll turn the key and all the lights go on and I'll hear 1 click (relay?). Then I'll have to turn the key again (sometimes only once, sometimes up to 20-30 times). The previous owner told me he had the starter motor replaced a year ago.
* Second: When I start the engine and pull i'll drive for about 500 meters (or around 40 seconds) and sometimes the engine stalls. I'll have to stop the car, put it in park and start her up again (without problems). Normally it happens when the engine is cold, but today I drove for a while and came back after 1.5 hours (motor wasn't cooled down entirely) and it happened again. Also when I start the car and leave it in park (had to remove ice from the windows) the engine stalls (sometimes). Almost like it dies when the choke stops? Note: It only happens when I start the car (thank God).
* Third: I'm aware of the fact that an older automatic gearbox always wants "to go", but it seems a bit extreme. When I'm driving it accelerates on its own. I think it does it up to 80 km/ph (50 m/ph), on the highway no so much and it slows down a bit when I have my foot off the gas pedal. I doesn't rev up and i don't have a feeling like the gas is stuck because I can hear a clear difference when I tap the gas a bit (engine revs up). It doesn't accelerate fast, but still I have a feeling that it's not normal.
General question: she has 225,000 km. (140k miles) on her. Fluids are good and of good quality. How should you drive such a car? I know she's not a racer and I shouldn't burn rubber at every traffic light. But should I drive in gears 3 or 2 sometimes? Kickdown and push her in high rpm's once in a while?
So what do you guys think? For the first 2 problems I'm thinking it could have something to do with the missing fusebox. I also noticed that the wires connecting to my battery are a bit old and not in tact (you can see the copper wiring). Maybe there's dirt between the connectors?
Third: Idle/Air Control System needs replacement? Although it's strange, I can't see or hear the engine revving.
Thanks in advance guys!
Arbi (Otto)
Arbi (Otto)
