Status
Not open for further replies.
1 - 20 of 24 Posts
Escalade
Can An AWD Escalade, be slammed and still retain its factory ride and shocks and NOT ruin the AWD. If it can is there a site or a book/video that shows how to do it. Everybody over here is lifting there trucks, I like to be different some I want to put her as low as possible without c notching. I would even consider total airbag replacement if theres a way to do that. Any help would be appreciated.
2010 Platinum Escalade, 1996 Fleetwood Brougham
-Yes an awd can be slammed.
- No it will not retain the factory ride.
-Yes it can be done without ruining the awd system.
There are several manufacturers that make parts/kits to achieve this, even bag systems. Since these trucks share parts with other full sized GM SUVs, I would encourage you to visit the Tahoe Yukon forum (Google), where you'll find more talk about this topic.
I was thinking about that. Don't know what the usual method is though. I thought of cutting the rods on them in half then thread them on each end to accept a turn buckle but not sure if they will come off the sensors easy enough. Then just turn the turn buckle until the desired height was achieved.
03 cadillac escalade
Cutting the rods is the easiest
It wouldn't take much adjusting afterwards to get the desired hight as they cause a bigger change in ride hight then you would expect
To lower the hight you raise the rod to raise the hight you lower the rod
08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
Assuming there is air in the bags lifting the vehicle, it may not go as low as you want it, maybe start by disabling the compressor and see how low it sits on the springs alone and go from there
I've got new Arnott shocks on it now and on level ground the bags are tight. There is definitely air in them when level. It just sits about an inch higher in the rear compared to the front.
Gm gave the escalade a "raked" effect from factory
Adjusting the lift/dive sensors will allow you to keep the factory suspension and level out the truck to remove the "raked" effect
It's been done by a few members on here and had great results
Awesome.......I'm gonna give it a try once it warms up a little. It's crazy to me to have the rear sit higher then the front when ya have a leveling system.
2006 Escalade ESV
Replacing my OEM rear air shocks on Sat. Currently still have the original ones that came with my 06 ESV. They still work but leak out air after 20-30 mins with the truck off. I like the "Raked" look...to each his own.
yeah I'm good with it too i also tow so what ever adjustment i make to level the vehicle will affect the lift that i need for leveling under load... I don't think we have as much rake as the short wheel base
I just like a nice level look. Trucks are usually raked like that so they level out with weight in the bed or a trailer out back with heavy tounge weight but these things are made to level out anyway with the amount of weight they can safely haul or tow. When I hook up my 19 foot bass boat to the back of mine the compressor will only run for about 30 sec or so and it jacks right back up to normal ride height and rides very well. Really surprised me with the short wheel base. I'm used to pulling with a truck so I wasn't sure how a short suv would do.
Blaze I have towed many times with my shorty escalade and it does great towing
It levels out even with a roughly 300 pound crt projector in the rear strapped to a pallet
On the hitch I can tow up to 3 ton without using tow/haul mode no problems
It's so stable no matter the load
Sounds good. I've only pulled my rig around the lake with it so far since I've had my Escalade but plan on pulling it over and through the mountains with it this spring and summer. Can't wait to see how it does power wise. It was about to wear my old 2001 ram out after a few years of pulling. The Escalade has about 100 more horses then my old truck so I'm expecting a pretty big difference.
It will make a difference for sure
Like the old saying goes there's no replacement for displacement
That's for sure. Although my old ram had the 5.9/360 in it. It was still way under powered compared to my Escalade. I think dodge only rated it at 245 horse back then and I think the 6.0 2005 Escalade is rated at 345.
1 - 20 of 24 Posts
Status
