1 - 20 of 20 Posts
T
Guest
Let me start with I love my car! However I have a few things that I'm sick of and hope you guys can help.
1. My B&M Shifter just sucks!- it makes so much noise that it's about to drive me nuts. I have put like five sheets of dynomat around it. What do I do to make it go away. Do I just go back to stock? or get rid of the B&M and buy the the other brand(forgot the name).
2. My SW long tube headers tick so loud that when I first had them installed I pulled over at least three times to make sure I had oil in my car. It make the tick noise at the collectors. I have no cats, and magnaflow exhaust. First off I want to buy some cats from someone because the car just stinks. I sit in traffic a bunch. SW sent me a new set of headers and I still have same tick. I have no leaks! Been to three places and all three say they have never heard headers tick that loud. I had heads and a cam done as well so could this be part of the cause? What do I do?
3. Rear end- As alot of you know I'm on my third one. Do not have the 06 though. Dealer tells me the noise is normal and so is leaking. I told the service advisor I would like to choke him and ask if it's normal. I was asked to leave! If I do get the 06 will it be any better? The one I have now has leaked for last 10K but it just does not break no matter how hard I try.
4. Radio volume button is flaked. Dealer said normal see #3 above. Have you guys been able to get fixed under waranty?
5. Rear door handle rattles- Dealer said it's normal because of my aftermarket exhaust. See #3 above. Ok it's the door handle with the fake chrome on it. How do I make it stop!
By the way did I say I love my car!
Also my wifes S-Type Jag caught on fire yesterday! At least this has not happened to the V.
crushing Vs with my Wurm
2013 GT500 - 700+ HP
1. Get a UUC...no noise.
2. Random Tech Cats...no issues on fitment
3. 06 is slightly beefier...have them install it and beat it senseless, then buy MM or Aussie rear and be done with it.
4. Not normal, you need new radio, should be under warranty as well. Many here have had the same issue, radio replaced no question.
5. Door handles and exhaust??? Shite, you need a new dealer. Its like saying you have flaking radio buttons cause you use unleaded gas....nonsensical.
Get a new dealer ASAP.
F
Owned 3 V's, now driving a Wrangler and XT5
First off, threatening a dealer will get you knowhere. Now you have to find another one.
1. The UUC shifter is the best they say.
2. I have no idea, sorry.
3. The 06 diff is much better, but not perfect
4. A dealer will replace just the knobs, but dont yell at them!
5. Another dealer issue.
Hope that helped.
:histeric: get a new dealer... you should scratch his car and ask "is that normal"...I haven't heard crap like this in a long time. Or better yet.. drive up here to VA and see James at Lindsay Cadillac.
No GET-RAG or GM products
Agree with F. Get a UUC shifter, no increase in noise from stock. Replace your current dealer with another. Anybody who tells you that radio knobs flaking is normal, is an idiot.
TEX, the guys are corect! as far as the ticking stainless is not the best
application for the street, it doesnt like the change in temp. I went
with TPIS & RT cats no ticking, there also coated, so theres less heat in
the engine bay, cam & heads are next:thumbsup:
Alexandria, Va
Work on them all...
Already said but... Get a UUC, you won't regret it... I even know where you can get one... :)
Only suggestion I can add would be to make sure all the joints/connections are tight and all the bolts/clamps are tight. Not 100% sure on this without seeing exactly where it's leaking, but this has been a problem with headers. One of the biggest reasons to not do headers IMO anyways.
Leaking is definately not normal... Depending on how bad the leak is that could be adding to your noise if the fluid is low...
If the finish is flaking off, should be under warranty. Volume buttons can be replaced without replacing the entire NAV unit ... See TSB here http://www.cadillacfaq.com/faq/tsb/data/05-08-44-029.pdf
Unless you have straight pipes & headers on your car without cats or mufflers I can't see it being the cause of a rattle.
T
Guest
Discussion Starter #9
Thanks guys! Anyone want to buy a used B&M shifter? And I have the stock one as well. James I will call you on Monday and order the UUC. Should I just take the stupid headers off? How much HP will I lose? Going to a new dealer today.
Sorry about all the problems your having but James is right on the money. I would try a set of headers from Kooks. I have had them on for two weeks and no problems with ticking or fitment. :highfive:
T
Guest
Discussion Starter #11
OK SW Long Tube headers and B&M Shifter for sale. I also have two G-Force KDW Stock Size with 1,000-1,500 miles as well.
Are you 100% sure it is the headers? My SW headers make no noise at all, how ever I had a lot of ticking sound, that sounded like the old solid lifters from the late 60"s. I talked to Phil about it and he said it was the profile of the lobes on the cam. I had him install a different cam- bigger while we were in there- with improved lobe design. NO MORE NOISE. Just thought I would share my experence with you, but with out hearing your car run, I can't say for sure if you have the same noise.
CTS-V
Now that is funny! Not very productive, but funny. I'm sure a lot of guys on this board sympathize with the dealer frustration and normal comments. A normal leak, that's one of the best I've heard.
Sorry about the woes with the V and the flaming Jag. Get your 4th diff (what's the record, anyway) and your replacement radio knob under warranty. Probably have to live with the ticking headers, unless you want to get another set or go back to stock.
Brian R.
2004 CTS-V
Buy the UUC shifter, get kooks headers, fire your dealer and get Bob to buy your wife & girlfriend some boobs.... oh, and a Z06 too. :yup:
04CTSVsc
tick-tick-tick = leak-leak-leak.
So, ask this dealer "if the rubber insert in my cup holder comes out, is that from my exhaust, too?"
You need a new rear (another) and a new dealer.
ew
1) I have the B&M shifter. Transmits noise when I rest my hand on the shifter. I have wrapped it to death with dynamat. Better, but not silent.
2) I had the BB headers. The new gaskets should fix your issues. Percy's plus copper sandwich. Percy's are on ebay, not sure where the copper ones can be found.
3) Three!? Three!? I'm on #6! You've got a lot of catching up to do.
4) Radio peeling. You're behind again. My third one goes in next week.
5) Door rattled after I installed the Infinity speakers. I found a loose connector and taped it down. No more noise. I do have some other creaks though.
Lemon Law'd '05 V
I also had some issues with the B&M. Here's what I did. Yes, wrap the stalk with some dynamat. Second, look underneath the car and make sure the rubber shifter bushings are seated correctly...then tighten the shifter down again. This made a GREAT DEAL of difference and now I only hear synchro sound during the shift. This may allow you to save the cost of a UUC and uninstall/install.
Some wish their Vs caught on fire....
-ace
Ace - I love your new location. :D Ah the subtleties of the forum. I love it.
1 - 20 of 20 Posts
