1 - 20 of 25 Posts
STS
1G6DX67D360200049
2006 STS-V
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/21/2006 39 miles 07/21/2010 50039 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/21/2006 39 miles 07/21/2012 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/21/2006 39 miles 07/21/2014 80039 miles
48/50000 FEDERAL EMISSION 07/21/2006 39 miles 07/21/2010 50039 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/12/2009 082419 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 45230 miles
12/03/2008 398153 # J9995 - CUSTOMER CONCERN NOT DUPLICATED - EMISSIONS 45145 miles
12/03/2008 398153 # K9995 - CUSTOMER CONCERN NOT DUPLICATED - AUTOMATIC TRANSMISSION 45145 miles
12/03/2008 398153 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 45145 miles
10/13/2008 394878 # K9995 - CUSTOMER CONCERN NOT DUPLICATED - AUTOMATIC TRANSMISSION 43789 miles
10/13/2008 394878 # Z7903 - 3-DAY COURTESY TRANSPORTATION 43789 miles
10/13/2008 394878 # J0250 - MANIFOLD, INTAKE - REPLACE 43789 miles
08/18/2008 391515 # J0103 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - LE 43369 miles 08/18/2008 391515 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 43369 miles
08/18/2008 391515 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 43369 miles
08/18/2008 391515 # N0110 - BATTERY REPLACEMENT 43369 miles
08/18/2008 391515 # K7580 - CLUTCH, LOW AND REVERSE - REPLACE 43369 miles
08/18/2008 391515 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 43369 miles
08/18/2008 391515 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 43369 miles
08/07/2008 390937 # J3401 - MOTOR AND/OR BLADE, ELECTRIC COOLING FAN - LEFT - REPLACE 43178 miles
08/07/2008 390937 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 43178 miles
08/07/2008 390937 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 43178 miles
08/07/2008 390937 # N1720 - FUSE REPLACEMENT 43178 miles
03/17/2008 381436 # J0667 - DRIVE BELT REPLACEMENT - ACCESSORY 38371 miles
02/25/2008 379891 # J0102 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - RI 38161 miles 02/25/2008 379891 # K5364 - TRANSMISSION CONTROL MODULE REPROGRAMMING [/COLOR]WITH SPS 38161 miles
02/25/2008 379891 # V1777 - 07204 - REPLACE REAR DIFFERENTIAL SEAL ONLY 38161 miles
02/25/2008 379891 # J0103 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - LE 38161 miles COLOR]02/25/2008 379891 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 38161 miles
02/25/2008 379891 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 38161 miles
02/25/2008 379891 # J3480 - WATER PUMP REPLACEMENT 38161 miles
12/10/2007 374722 # J9995 - CUSTOMER CONCERN NOT DUPLICATED - EMISSIONS 36406 miles
12/10/2007 374722 # K6350 - SWITCH, AUTOMATIC TRANSMISSION MANUAL SHIFT SHAFT POSITION 36406 miles
12/10/2007 374722 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 36406 miles
12/09/2007 R58468 # Z2085 - ROADSIDE SERVICE (PREMIUM) 40000 miles
12/09/2007 R58469 # Z2080 - ROADSIDE SERVICE (TOWING) 40000 miles
10/30/2007 027916 # Z7902 - 2-DAY COURTESY TRANSPORTATION 33765 miles
08/30/2007 367407 # E4301 - BEARING AND HUB ASSEMBLY, REAR WHEEL - LEFT - REPLACE 28631 miles
08/30/2007 367407 # Z7903 - 3-DAY COURTESY TRANSPORTATION 28631 miles
04/02/2007 356031 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 16254 miles
04/02/2007 356031 # Z7902 - 2-DAY COURTESY TRANSPORTATION 16254 miles
01/11/2007 349936 # E8625 - HOSES, POWER STEERING HYDRAULIC - RETURN, GEAR TO COOLING 10862 miles
01/11/2007 349936 # Z7903 - 3-DAY COURTESY TRANSPORTATION 10862 miles
01/09/2007 349818 # E9740 - STEERING GEAR REPLACEMENT 10810 miles
01/09/2007 349818 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10810 miles
11/06/2006 345235 # N0110 - BATTERY REPLACEMENT 7438 miles
11/06/2006 345235 # Z7902 - 2-DAY COURTESY TRANSPORTATION 7438 miles
11/06/2006 345235 # C2326 - INSTRUMENT PANEL CENTER TRIM PLATE REPLACEMENT 7438 miles
11/06/2006 345235 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 7438 miles
10/23/2006 H26273 # Z2083 - ROADSIDE SERVICE (BATTERY/JUMP START) 5000 miles
04/14/2006 330855 I Z6999 - PDI RELATED FLUID ADDS 10 miles
04/14/2006 330855 # B1790 - WINDSHIELD WASHER NOZZLE HOSE REPLACEMENT 10 miles
03/28/2006 A00049 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
194 - EBONY
19I - EBONY INTERIOR TRIM
1SA - STS-V EQUIPMENT: * 4.4L NORTHSTAR V8 SUPERCHARGED ENGINE WITH 469 HP/439 LB-FT TORQUE * 6-SPD AUTO W/DRVR SHIFT CNTL * PERFORMANCE TUNED SUSPENSION * PERFORMANCE BREMBO BRAKES * 18" FRT & 19" RR ALUM WHLS * P255/45R18 FRT, P275/40R19 RR EMT PIRELLI TIRES * REAR V-SERIES SPOILER * LEATHER WRAPPED INTERIOR, INCL. DOOR TRIM, CONSOLE, IP
1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK RAVEN
6LL - COMPONENT FRT LH COMPUTER SEL
7LL - SUSPENSION
8ZM - SUSPENSION
9ZM - SUSPENSION
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DL5 - DECAL - ROADSIDE SERVICE INFO
DR2 - O/S REARVIEW PWR, HEATED MIRRS
FE4 - SUSPENSION
FE9 - 50-STATE EMISSIONS
GU5 - AXLE REAR, 3.23 RATIO
IL4 - TRIM INTERIOR DESIGN
J56 - PERFORMANCE BREMBO BRAKES
JJA - PT DRESS SUBASSEMBLY INSTALLED
KG4 - 150 AMP GENERATOR
LC3 - 4.4L NORTHSTAR V8 SUPERCHARGED ENGINE WITH 469 HP/439 LB-FT TORQUE
MX0 - MERCH 5-SPEED AUTO TRANSMISSION
MYC - 6-SPD AUTO W/DRVR SHIFT CNTL
NR7 - HEATED LEATHER STEERING WHEEL
NT9 - EMISSION - FEDERAL
Q19 - P25545R18 FRT, P27540R19 REAR
Q20 - 10-SPOKE WHEELS
R6P - PREMIUM PAINT
R8E - GAS GUZZLER TAX
R8K - *******************************
R9N - LEATHER.
ROO - ORDER FULFILLMENT TRACKING
SLM - STOCK ORDERS
TQ5 - INTELLIBEAM AUTO HIGH BEAM CONTROL
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
UE1 - ONSTAR SYSTEM INCLUDES 1 YR DIRECTIONS & CONNECTIONS
UG1 - UNIVERSAL HOME REMOTE
UY5 - 15 SPEAKER SYSTEM
V73 - VEHICLE STATEMENT USA/CANADA
YQ4 - BOSE 5.1 STUDIO SURROUND SOUND WITH IN-DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES
Please see claim history above.
I am looking at buying this STS-V and am concerned about the manifolds being replaced three times. Is this normal for this car? I have also noticed a lot of battery replacements on the STS Vin #'s I have had checked. Is it normal to have so many battery replacements on STS's?
Any thoughts would be appreciated before I pull the trigger on this car.
Thanks,
Steve
'06 STS-V; '10 STS 1SG; '08 Escalade, '08 Escalade EXT
Thanks,
Steve
Good lord! Thats quite a laundry list for a 45k car! Most of us (exception of CIWS, and inurok) have had engine or transmission related repairs.
Mine has 16k on it now and most of my issues has been rather small.. Wheel hubs, Updates to NAV, PCM, TCM, steering rack squeaked when warm, etc.
I'll let everyone else chime in but waterpump, cats, intake manifold, etc.. looks a little hairy..
2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
ive had the exhaustmanfold and cat replaced its all one peace on our cars mine has 25K on it
Was it for the Cat being bad ?
I had a lower crankcase seal leaking at around 3,000 miles and they pulled the engine to fix it. Upon replacement they muxed something up with the supercharger and damaged the lower door panels in the process, so it had to go back to them so they could resolve those issues.
09 cts4 04 cts-v
yes from the cat being bad ive just noticed that my oil pan is wet it looks like the oil pan gasket or the front cover is leaking
Here's what mine looked like. Discovered it while it was on the dyno.
Now as I was told that leak wasn't that bad, too the degree that if I hadn't discovered it and said something to them about it, and they saw it during a oil change or something, they would have just wiped it off.
That's a little disturbing because little leaks can turn into big leaks and Murphy says it will happen at the most inconvenient time it can.
none
:rant2:
1G6DX67D360200049
2006 STS-V
CLAIM HISTORY
02/25/2008 379891 # J0102 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - RI 38161 miles 02/25/2008 379891 # K5364 - TRANSMISSION CONTROL MODULE REPROGRAMMING [/color]WITH SPS 38161 miles
02/25/2008 379891 # J0103 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - LE 38161 miles COLOR]02/25/2008 379891 # 02/25/2008 379891 # J3480 - WATER PUMP REPLACEMENT 38161 miles
OPTION CODES
194 - EBONY
41U - BLACK RAVEN
7LL - SUSPENSION
8ZM - SUSPENSION
9ZM - SUSPENSION
FE4 - SUSPENSION
R6P - PREMIUM PAINT
R9N - LEATHER.
SLM - STOCK ORDERS
Thanks,
Steve
I don't think that's any worse than mine, but I LITERALLY dream up reasons to bring my car in...:stirpot:
What I do see is it did take them a while to figure out what was knocking out the cats, it, more than likely, was that intake manifold problem. Keep in mind that cats DON'T GO BAD ON THEIR OWN,THEY ARE DRIVEN BAD...most likely due to a drivability issue like poor mixture or engine misfire...either one causing the cats to work too hard and burn themselves out.
That car probably had a reeeealy picky owner(someone like me, for instance). I can tell by the high number of NPF's, and / or bad technicians who are having trouble diagnosing the problems reported.
A Service Advisor who doesn't know the charictaristics of these cars can send a technician looking for a problem that does not exist, as well.
So, no,you have no real need to be concerned. But, I will advise you as I do my friends. You do not want to own a late model, high tech automobile without the FACTORY AUTHORIZED EXTENDED WARRANTY for as long as you can afford to pay for. I mean that! :rant2:
STS-V engine is over $13,000 retail...nobody fixes them and you don't want to let them, trans is over $5,000, s/charger is $5,500...etc....Get a warranty, drive it and enjoy it.
:rant2:
...STS-V engine is over $13,000 retail...nobody fixes them and you don't want to let them, trans is over $5,000, s/charger is $5,500...etc....Get a warranty, drive it and enjoy it.
The first part sounds like me :) -- Mine has new seat covers on order as we speak because they are 'crinkling' (photos upon request) and is getting a little excessive. And no I don't mean a wrinkle, I mean like the leather is stress cracked in some areas. Only the drivers seat back and the right rear bottom seat cushion has done this but nevertheless. The other areas are completely wrinkle free and 'crinkles' so its very odd. Service manager at my dealership didn't that that should be normal by any means.
STS
Discussion Starter #12
What about the battery issues? Many of the STS's I have looked at have had numerous battery replacements. One of them has had three batteries in only 35,000 miles. Is this a normal problem with this model? Is it because of the many accessories installed on these cars?
Have any of you had excessive battery problems?
Thanks,
Steve
Thanks,
Steve
It seems like most of the folks experiencing this are ones that don't use the car as a daily driver and the car sits for a week without being driven. However I will say I don't think the stock AC Delco battery is all that great for this car, which is why I went ahead on my own and swapped it for an Optima Redtop battery.
Formerly 06 STS-V, now 13 XTS
Thanks,
Steve
I'm on my second battery. My STS-V is a daily driver, and one morning, the battery was just dead. No warning, just completely dead. Fortunately, it was in my garage at home. I jumpstarted the car and drove it to the dealer. They replaced the battery under warranty with another OEM battery. No problems since.
They said that the original battery had a cell go bad.
At 45K miles you may have another 5K before the warranty is expired. You DO NOT want a car like this without a warranty behind it. Not because it's a problem car, but in case something does break you do not want the repair bill. See if they will sell it Certified Pre-Owned (may cost extra), or check into the cost of having the GMPP extended warranty put on it right as you buy it.
09 cts4 04 cts-v
i havent really had that many probs with my car other then the rear end getting replaced and the cat going bad my wheels the clear is coming off some of them and the dealer i go to wont replace them and the front seat bottoms look like shit but they also wont replace them they will spray them but i said no thanks to that. My car is still under fact warrenty and i am also cert till its well worth paying for it if the dealer will do it or the gmpp just to have something if you plan on keeping the car for awhile other then the 2 things ive had the car since 18Kmiles and now has right around 26K on it and has been awsome
1 - 20 of 25 Posts
