1 - 13 of 13 Posts
2005 Deville base
Ok so I have an 05 Deville base model with 83k miles 2nd owner and I'm bringing her back to life...so I went and had suspension looked at and the bushings with the control arms are fully shot and the air shocks need replacing so what I am wondering is there a special place you all go to for your parts or do you just go with cheapest or middle of the road best deals...???...there are many of you that are very seasoned and knowledgable and that is an excellent database for us noobs to be able to access and I thank you all for that privilege as well as thank you all for your inputs...I am wanting to do the right thing for this car as it is a Memorial to my Mom so it can pass to my son as well...馃榿馃...Thank you
WHAT you buy is much more important than WHERE you get it from -
I use rockauto.com to get part numbers - VERY easy to use catalog -
sometimes they have the best price - sometimes not - they DO charge for shipping -
amazon.com -
also look at amazon "used" parts - they are usually brand new parts in beat-up boxes -
ebay -
walmart - YES - you can order auto parts and pick them up at the local store -
Farm&Fleet - they also charge for shipping -
NEVER the dealer -
almost never - the local auto parts store -
SOME things should only be replaced with genuine ACDelco parts -
two VERY common items that come to mind immediately -
spark plugs and oil pressure switch -
some OEM parts are discontinued and the "dealer replacement" parts are JUNK -
a prime example would be rear shocks -
the dealer replacement is actually Gabriel hijackers with an ACDelco sticker -
these require modifying the air line at the shock - AND - replacing the pressure spring in the compressor -
a MUCH better choice is the Monroe MA822 -
ebay has them for $65 - for the pair - with free shipping -
amazon usually has the best price - under $60 - but they are $68 now - they DO have a "used" set for $45 -
rockauto.com has them for $71 - including shipping -
for front struts - I also recommend Monroe over anything else -
for control arm bushings -
I recommend replacing the entire control arm - BONUS - includes a new ball joint -
MOOG is quite a bit cheaper than ACDelco - and every bit as good -
if you ever have a question about specific parts - just ask - that's WHY we are here -
83k miles and the bushings and shocks are shot? I hope your shop isn't taking you for a ride. Times are tough and everybody is trying to maximize profits. Even dentists are doing work that is unnecessary.
2005 Deville base
Yessir one would think so however...I got under there with them and looked it over with them and the bushings are shot man so it was disappointing but I am going to get her done and I will always run anything Cadillac thru this forum page...馃榿
2005 Deville base
amazon.com -
ebay -
NEVER the dealer -
Yes basscat cannot appreciate you all enough and thank you for the info...yes I found out that the control arms will be the whole thing rather than just the bushing...I will look into those numbers you gave me and get on it asap...Thank you again sir...馃榿
2005 Deville base
amazon.com -
ebay -
NEVER the dealer -
Good morning Basscatt...so I found the MA822 shocks at oreillys for 73 and I'm good with that now the control arms I am confused about...I looked at rockauto and they have one arm however I am confused on the numbers and they have economy...daily driver...premium and some other option...like there was a heavy duty option too...???
2004 Deville
2004 Deville, Silver, Gone, but not forgotten, 1972 Eldorado, 1974 eldorado, 1975 CDV
If the description says FE1 or FE3 those are the ones you want.
NOT TRUE - dentists are shut down except for emergencies -
heavy duty would be for commercial chassis - 6-lug wheels -
here are the control arms I recommend for your car -
front - left - MOOG RK620291
front - right - MOOG RK620292
It has to be true, I read it on the internet. I'm sure this was before the pandemic. I have seen greed all my life and I trust no one.
oh - well - then - it MUST be TRUE -
I stand CORRECTED - ;)
It was tongue in cheek dude, you caught that. I still trust no one.
I do trust my dentist because they know I am cheap and we discuss everything
1 - 13 of 13 Posts
