2004 Deville
Please could someone help me. I have replaced the rear shocks and can he the compressor working but shocks will not pump up where should I start looking to solve the problem. thank you for any help with this.
Spray the lines with soapy water while the compressor is running, bubbles indicate a leak.
Less likely but possible, the compressor is leaking or no longer able to provide sufficient pressure.
start by checking for Diagnostic Trouble Codes -
if you don't know how - go here and read the ENTIRE post -
http://www.cadillacforums.com/forum...ncluding-1985/138257-how-pull-codes-dtcs.html
if you have any codes - post them here -
ALONG WITH THEIR DEFINITIONS -
we are looking for an EXHAUST SOLENOID related code -
if no codes -
withn the compressor running -
remove the airline from one of the shocks -
hold your thumb over the end to determine that you do have air under pressure -
if OK - plug the line back in -
and as MC suggested -
spray soapy water on the lines and watch for bubbles -
2010 DTS
What shocks did you install?
Did you connect the pressure line correctly including the retainer?
1973 Cadillac Hearse, 2002 Cadillac DHS
On my rear shocks there are also tiny o-rings on the ends of the lines where they fit into the shocks
