1 - 12 of 12 Posts
1997 ETC
So i have some brand new Monroe 40018 CVRSS shocks sitting in my house unboxed, i'm contemplating whether to wait until i can purchase the front CVRSS struts or just go ahead and install these since i'll be in their replacing the calipers, Rotors and pads on all 4 wheels anyways.
Or
Or should i replace all bushings once i get the struts, then do the brakes.. confuzzled, lol
Or
how bad does it need the brakes?
you are going to need an alignment with the struts -
and you are going to need an alignment after replacing the rear bushings -
1997 ETC
Ive a shaky steering wheel when i brake..
]you are going to need an alignment with the struts -
Ok, just figured i want as much new parts installed at the same time as my wallet will allow, if i play my cards right in the next few months, i can have all things replaced in the course of a few days, shocks, struts, bushings, calipers, rotors, pads etc
1997 ETC
Sounds like you have the right plan.
I'm curious, what are your plans for bushings?
Thanks,
Taz
I want my ride as factory new smooth as i can get. So if i can score rubber bushings rather than polyurethane i will. Both have their trade offs, so we'll see.
02 Seville, 04 SRX (sold), 96 Eldorado (sold), 99 DeVille (sold)
If you don't mind jacking the car up again, just install the back ones when you have some free time. It will only take about an hour to do both and you don't have to mess with anything other than the bolts holding them on. This is assuming that you are doing them yourself. If you bring your car somewhere, then I would have it all done at once to save on some labor.
1997 ETC
Discussion Starter · #7 ·
K, question. I have my front strut (Front right 40016) and i'll be getting my 40017 (front left) this week. I'd really like to replace or service any other suspension components as much as possible, i don't want to slap on $350-$400 struts/shocks only to have a bushing or tie rod fail..
If the bushings appear cracked or worn should i replace them? How hard is it to do so myself?
1999 STS - diamond white
You have 2 40018's for the rear? Shouldn't there be an odd numbered part for the opposite side like there is for the front?
2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
With my BMW I replaced all 4 shocks/struts and tie rods at the same time to save cost and have just one alignment done. If the bushings are cracked they are worn and will need replacement sooner than later. What I don't know is how hard the bushings are to replace yourself. On that BMW I had to have special tools rented to have them replaced so that might be the case here.
1997 ETC
Discussion Starter · #11 ·
Ok, going to place an order today for the final strut (monroe 40017). Should i order new strut mount kits also?
2000 STS, 223K Miles, 1985 Corvette, 110K Miles
Vincent,
When I did my HG repair (Saga of a Naive Head Gasket Repair) I also put a bunch of suspension parts in: brake pads, rotors turned, bearing packs for front, Monroe CVRSS struts + Monroe mounting kits for both.
With approx 6K miles on the rebuild, I did a trip to Las Vegas (from Kansas) in January. The interstate I took on the way back was HORRIBLE! The signs said 'Rough road next 75 miles' and they weren't lying. It was soo bad that it destroyed the passenger side strut mounting kit, breaking loose the rubber, allowing the strut piston to smack the underside of the hood every time I went over any kind of bump/concrete joint in the road. I could see the hood jumping up near the windshield. I took it easy and made it to Denver, where I had a dealer put in a new mounting kit. And now, with the benefit of hindsight, I SHOULD have had them replace both - as the driver side went out on me two months ago.
That has been my experience with the Monroe strut mount kits. YMMV
Cheers,
Steve
1 - 12 of 12 Posts
