1 - 9 of 9 Posts
05' CTS with the 6 speed manual & Sport suspension.
WOW what a pain in the rear. Replaced the shifter bushings on the 6 speed manual, transmission side, well all actually since it was apart. Darn pin was seized in from corrosion and bushings we're completely wasted.
Had to drop exhaust and drive shaft, which I seen on here people were doing it without, IDK how.
Shout out to Creative Steel. Fast friendly service, great product.
Discussion Starter #2
Now to replace a rear strut. FE3 hopefully it goes better. Any trade tricks out there.
Well that went well, it took longer to remove back seat than it did to change the strut's. FE3 strut's are definitely larger diameter than FE1--
I wouldn't advise trying to cheap out here.
'05 CTS-V
The bushings may have been a pain in the ass to replace, but they should make the shifter feel a helluva lot better and make the car way more enjoyable to drive.
2007 6 speed manual tarnished platinum
Ya mine totally seized in the end of the shifter too, nut came off and could turn it with the hex side but just spin. Ended taking the shifter out and couldn't even hammer it out. Couple of Dremel discs later and it was out. Have the creative steel delrin bushings at the trans end(great) but couldn't wait around to order the shifter end. Couple of bronze oil impregnated bushings and a lot of filing later it shifts better than ever and can get it in reverse again.
1 - 9 of 9 Posts
