crushing Vs with my Wurm
2013 GT500 - 700+ HP
Fellas,
James at Lindsay was kind enough to sell me 2 bushings for the shifter plate linkage. A couple of thoughts...I installed mine from above, by removing the console (6 10mm bolts) and after looking thought there was no way to get at it. Im 6'2" tall and 210 lbs with Bob Evans missing links for fingers, so I thought I was doomed. It took me 2 hours of fiddle fudging around to get em in, but theyre in. I was thinking of getting under the car to do it, but Id have to drop the exhaust and fart with that and that didnt seem to be the logical way. As CVP33 has pointed out, use lots of lube, otherwise itll be a russian standoff between you and your bushings. Everything back together and lubed, and it feels even slicker than with the UUC alone.
Great Job on the bushings (Lastss, I think?) theyre sweet.
F
Call James, he'll hook you up. From what has been posted here, they will work with the BnM shifter. They go under the mounting plate in front of the shifter, I cant see why they wouldnt work unless the BnM has some funky doins.
F
