Good Morning,
I have been having a weird electrical bugs the past few weeks. I noticed one day that my remote was not unlocking the doors. I unlocked it with the key and the truck was completely dead. No lights, no crank, absolutely dead. I did all normal cursing and pleading with it and tried to move the steering wheel and jiggle the key but nada. Then I noticed something weird, with the key in and turned, I was able to hit the brake and then the truck made some mechanical noise and started. Today I noticed the same deal when I tried to unlock it. I again had to open the door with the key and went to start it and again, it was dead. This time with the key out, I hit the brake (which did not start it like last time) but was able to move through all the gears. When I shifted it thru all the gears, I then again heard that same mechanical whirring and the lights came on. I was able to put it in park put the key in and it started like normal. I am pretty concerned with being able to sit in the truck and just shit it from park to any gear with no with no key for safety reasons. Since my drive way it slightly sloped, I always us the emergency brake but still....
The alternator went out a few weeks ago and I had that replaced under my extended warranty. The starter was also starting to miss, so that too was replaced. The battery is a Duralast that was replaced 2 years ago. I did notice that in the last few weeks my radio being reset in the morning so obviously the truck was disconnecting power for whatever reason, but it always started. Last thing I have noticed is the battery gauge is fluctuating between 12 and 13.5ish volts at idle.
Just wondering has anyone experienced the same issues here? I am trying to research as I am sure there is some sort of relay/module/security that is malfunctioning because the battery is not being discharged as it seems more being cut off.
