Mechanically this is not a problem but it sure can irritate.
I don't know your model but behind the fascia beneath the steering column is likely to be a cord which is attached to the indicator on top of the steering column.
The cord anchor has shifted or come loose.
Locate the cord and it's anchor and you will be able to adjust to align correctly by pulling it down or letting it go up.
The indicator is static whilst the gearshift column moves.
This was the case with my '81 Deville
This should not be a major problem.
