Hello
Cadillac Seville STS 1998.
Last week i saw an oil in overflow tank. Now there is very big pressure in coolant system immediately from even cold engine start so that coolant is (dont know right word) pushing out from there. Plus i can see exhaust fumes.
So...
I need head gaskets, or better full set of engine upper gaskets. Do I need to change bolts?
In other post i read:
'If you need head gaskets you MUST Timesert the block - Timeserts, Norm's Inserts or Jake's studs.'
What does it mean? Normally it was just to remove head, check it if it is OK, replace gasket and mount head again... No special procedure.
Maciek
So...
Maciek
