1 - 11 of 11 Posts
1997 Seville STS
Hallo everybody!
I need to replace old struts but original ACdelco 580116 are too expensive.
Are there substitutes for them? I would like to leave the electronic leveling system, but what are the most common options for replace?
Thanks in advance!
Re: Seville 1997 struts w/
Struts in front, shocks in rear. Level system uses auxiliary bladders and a compressor system on the shocks only. On your RPO sticker under the spare tire cover - what are the suspension codes - FE1 or FE3 - F45 ?
If the suspension is active
- CVRSS - then basscatt has the part numbers and technique for replacing the active parts with less expensive passive Monroe parts. You also need to do an electrical trick to fool the suspension control modules. He has that, too.
Different trim levels require different parts - please update your profile to show which Seville you have - SLS or STS.
1997 Seville STS
Thanks! I have Seville STS. Suspension is active. I know that active is replaced by passive, but is there any active options like remanufactured or custom?
No. Monroe used to make aftermarket active units, but they're discontinued.
You can get passive replacements that are compatible with the ELC system. Most here will recommend Monroe.
SLS 1997
The mechanic told me I needed to replace my (front) struts. Here in The Netherlands we have a yearly check which your car needs to pass (APK). They check all sorts of stuff. Suspension being one of them. Now I have the same problem as you: don't want to pay $1200 per side.
After looking through this forum I found the Arnott replacement. They keep the air leveling system operational and you don't have to disable the suspension control module.
https://www.arnottindustries.com/part_CADILLAC_yid6_pid38.html
Could someone tell me the difference between these and the one Monroe sells?
The difference is the Arnotts are overpriced junk.
If you install passive shocks/struts, you need to install resistors to trick the computer into thinking they're active. You aren't disabling any modules.
The resistors cost pennies, Arnott charges hundreds for the convenience of the resistor being plug and play.
Wiring in your own resistors takes minutes. There are plenty of threads on the subject.
1997 Seville STS
Arnott is cheaper. But I know a car where they are installed for about 6 years - and they work fine.
Arnott is cheaper for a reason. Use the Monroe or original AC Delco product.
Oh so you're just looking at their passive replacement, not the "conversion kit". Either way, junk.
Could someone tell me the difference between these and the one Monroe sells?sure
the Monroe struts and shocks are HIGH QUALITY units -
that are a GREAT value -
arnott are WAY overpriced - LOW QUALITY - junk - passive struts/shocks -
with a ridiculously overpriced resistor that does EXACTLY the same thing -
that the RadioShack resistor does -
AVOID them -
1 - 11 of 11 Posts
