1 - 14 of 14 Posts
1996 ESC
I decided to go to the casino last night .. I m in bama..casino was harrahs ..3 hours away ..AGAIN please know this is my first time having access to the info center ..I gassed up like after 2 hours of driving .. got back in ..I seen the sevice transmissin light on the dash ..I payed 1200 $ to have the tranny fixed 15 months / 30000 miles ago ...tranny fluid looked fine,, IT RAN FINE...not 1 hiccup...any suggestions ... I m a pull all the codes now .. current n history.... any ideas ?? TY in advance !!
1996 ESC
Discussion Starter #2
I ran to the store.. the service trnny light is no longer on ..I have ALOT of codes .. I hope all the H ones are history and over with ?? these are the ones with the H by them ...RS 0061 H PC 0603 H PC 0741 1406 1644 all H..IP 1552 H .. a bunch oh P codes all H 1552 1971 2056 2255 2470 2473 ....I have 2 current RS 0038 and TC 0073 .. please tell me all I have to worry about is the current codes ? I m a guess the TC 0073 .. is why my traction control light is on .. please give me a starting point TYTY
Any historical code means that the fault has not been detected in at least the last 3 drive cycles.
Codes are meaningless numbers without their definitions. No one has them memorized. Always post definitions along with your codes.
SLOW DOWN - - TAKE A BREATH - -
the "starting point" would be to list the COMPLETE codes -
and their DEFINITIONS exactly as shown here -
also include whether the codes are C-Current or H-History -
example:
P0741 - TCC System Stuck Off - History
1996 ESC
T073 . PCM - EBTCM/EBCM Pulse Width Modulation Signal Fault i THINK thats the TC 0073 definition since my traction control light is on ?? Te second code..RS-0038: ELC exhaust valve short to ground/open circuit ..... i geuss cause my baldder bags or springs are bad ?? any help is apprecitaed TY in advance !!
that points to an ABS module problem -
this one basically says the ELC - Electronic Level Control - compressor is shot -
IF the air bladders in the shocks are still good (doubtful)
you COULD install the MONROE AK29 - manual-fill air line kit - around $15 -
and inflate/deflate the shocks as needed when the load changes -
IF the shocks need replacing (VERY likely)
I recommend MONROE 40046 - $90 each - with free shipping -
and use the AK29 manual-fill kit -
1996 ESC
is the ABS module .. the same as the traction module below the water pump .. theres a junk yard by me .. I took several parts .. last week I fixed .. my NO RFA data .. with a new RFA box off of it. for 5 bucks...the owner told me he actually drove it off the flatbad and he .. was gonna fix it but never did
1996 ESC
Discussion Starter #8
that points to an ABS module problem - when my traction light first lit up on my dash .. i asked my mechanic .. he says its PROBLY .. just a bad wheel sensor .. and no biggie .. next time we go in there ,, we ll get it ...THE QUESTION would a sensor make the traction light come on ?? or does this code mean i need a need a new module ??
starting multiple threads on the same issue is a NO-NO
it takes up space and makes it hard to follow -
T073 Is more likely either the VSS or one of the wheel speed sensors.
VSS = Vehicle Speed Sensor. It's on the right output shaft. Accessible through the RF wheel house.
584445
VSS ?? means the Vehilcle Suspension ststem ??
From the stickies at the top of this forum's threads page............
Always read all the stickies in any forum of interest - timeless info.
As posted, the VSS is on the right output shaft housing, just in front of where a passenger's toes would point.
1 - 14 of 14 Posts
