Hello. Seeking some help. I am the owner of a 2002 STS. I am hoping you can help me with a situation involving my front electric struts. After replacing them with passive air struts, I have no place to plug the remaining wires and I am now getting a message that says. “Service Suspension Sys/Limit Speed to 90 MPH” along with 2 DTC codes C0579 and C0584.
I searched the forums and found out about something called the resistor trick using 4.7 kohm, ½ watt resistors. I took 2 pieces of wire and soldered them to both ends of the resistor. I did this twice with both resistors. I cut off the wires harnesses that were connected to the electric struts, stripped the wires and butt spliced the resistor/wires to the strut wires. (One on each side of the car) The message has not gone away, which tells me I did something wrong.
Any idea what I did wrong? Am I supposed to attach the wires and then reset the DTC computer? Or am I missing a step. Please. Any help that you can give me would be awesome.
My car was built 04/02 so I think it’s the F55 Magna-Ride system.
Threads merged from new model "STS".
