2005 Cadillaic CTS 3.6L
Hi guys, need some help here.
My 2005 3.6L CTS luxury+sport (117K miles) recently started to show a message "serve stability system" on the message center. No CLE light is on. I can press control to clear the message and everything looks normal. The message often shows up when I slow down to make a stop at a traffic light. Any idea what is happening with my CTS?
Additional information:
1. My CTS shakes a bit at idle when AC is on. If I turn off the AC, there is no shaking anymore.
2. Just replaced the 6 spark plugs last summer. Seems to be working great.
Thanks in advance!
2006 STS V8 1SF RWD
Re: Serve stability system
With the Service Stability System message present get the diagnostic codes scanned with a scanner capable of reading Chasis (C) codes, those won't set a CEL, only Powertrain (P) codes will do that. Come back with that code and we can be much more helpful.
Thanks!
There is no code stored at ECU from obd reader. So, i nwed a different scanner?
06 CTS Sport/Luxury package
You'll need a scanner that can read Chassis and or Body computers. The price tag on those types of scanners are normally $150 and up.
Anything below that will 99.99% be just for the Powertrain computers.
KOT
Thanks, KOT!
Is OBD II, CAN & ABS Scan Tool good enough? Could you recommend one?
2006 STS V8 1SF RWD
Try an auto parts chain, some stores have scanners capable of reading these codes, they'll do it for free.
