2003 DHS
2003 DHS. I am beginning to get "Service Stability System" presented occasionally on start. I assume this is a routine message that something is due, but do not understand what needs to be done.....except pay more money to the dealer. Can someone explain this to me? Thanks.
I'm having the same message on my 98 Concours come up occassionally. But I've also noticed that the Traction Control is kicking in sometimes when I start from a stop on dry pavement. If I let up on the gas it kicks off again. Anyone can help?
· Cadillac Technician
none
Some codes are set, there is no maintenance service interval for the stability system. Check codes.
Unwanted TCS activation can be due to many factors, a faulty hub, wiring problems or even EMI (induced false signal voltage from an outside source, such as weak or faulty ignition components).
That should be diagnosed also.
