1 - 12 of 12 Posts
2002 ascalade
turn your key on and press your gas pedal 3 times. service ride light means you have a suspension problem-bad shocks etc..I just bought after market shocks regulsr-$275 on line works fine and bought kit to turn off light $60. OR you can spend as much as you want to fix a problem that will re-occur(electronics) Cadillacs are good NEW!
escalade
are you joking about pressing the gas pedal 3 time? sorry noob.
That's correct. I had to reset my oil life indicator yesterday. Turn the key to the on position (second click), press the gas pedal three times, and turn the key back to the off position. Now start your vehicle and you should see the "change engine oil" light blink three times. This means the indicator is reset.
1 - 12 of 12 Posts
