I know you said your not putting air back on and want to bypass the sensor on the shocks I took air shocks that were busted off and replaced them with gas shocks. Have you figured out how to get the SRC light to go off? I'm lifting mine and took the 26s off to put 35" tires on it. So with lift kit air shocks won't work but. That light is bothersome. If you have answer please post.
I saw a video the guy used 40ohm resistor and took the white and blue wire from right side of compressor and hooked one side to each wire and said it turns light off I'd much rather buy a plug and play unit than radio shack resistor.
