Hello all,
There have been V2 owners concerned on how to remedy an observed wheel clicking.
A few responded that removing the front wheels and reinstalling is a fix. This terse action will only serve as a temporary condition.
Please review the procedure below for a more robust solution. This info will immediately help efforts of both owners and dealer service.
I will post the official TSB once it is approved for release.
Vehicle: MY2009 CTSV
Condition:
A clicking noise has been noted emanating from the front wheels. Condition is noticed at low speeds (walking speed) during full wheel lock turns.
(Full lock parking lot maneuver).
Clicking noise is generally noted as approximately 1-4 “clicks” per wheel revolution.
Cause:
Interaction between wheel mounting face and wheel mounting surface on rotor.
Correction:
It is recommended the procedure below be completed on both front wheels.
It is not necessary to clean rear wheels for the “clicking” condition.
Procedure:
Remove wheel
Clean wheel as follows:
•Use clean cloth dampened with GM Brake Parts Cleaner 12378392 or equivalent.
•Wipe the mounting surface of the wheel to remove and residual grey or black material that has accumulated on the wheel mounting surface.
Clean rotor as follows:
•Clean the wheel mounting surface of the rotor to remove and residual grey or black material that has accumulated on the wheel mounting surface.
•During cleaning process be sure to clean the rotor near the wheel pilot at the center of the rotor.
Reinstall wheels. The wheel nuts should be tightened to a service torque of 215Nm (158 lb/ft).
Note the increase wheel nut torque (190Nm to 215Nm) - (for forged CTSV wheels only).
You will recall the 2004-2007 V's wheel is a six bolt pattern. The V2's 5 bolt pattern was accomplished by using truck size lugs (forged wheels), hence the higher torque level required. A great piece of data for those of us that like to work on our cars personally. Cast wheels and steel wheels should be torqued to lower spec.
OFF TOPIC: The track opens tomorrow! :lildevil:
Mike
Condition:
Cause:
Correction:
Procedure:
Remove wheel
Mike
