1 - 20 of 54 Posts
2013 Cadillac XTS Luxury
The sticker that has the RPO codes on it is usually on the inside of the deck lid or maybe stuck to the board that covers the spare tire. Hope this helps.
2015 XTS FWD 2020 CT5 Prem Lux 3.0tt
You have to remove the black plastic cover for the cargo net. unscrew the hooks and remove the cover. The label is on the floor on the left side.
2014 XTS Platinum VSport AWD
Does anybody know where you find the RPO label in a 2014 XTS? I looked in the trunk and around the spare tire cavity, but I didn't see it. Thanks.
1999 STS,2013 XTS-P, 2014 XTS-P
To the left of the spare tire cavity and under the carpet. Do a search here and you'll find tons of info on how to get to that sticker.
'02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
2018 CT6E, old: 2014 XTS Vsport, 2005 CTS-V, 2004 CTS-V.
2014 RPO
Description
ACO
IDENTIFICATION – ACCESSORY CATALOG OFFERING
AEF
WINDOW – POWER OPERATED, PASSENGER, EXPRESS UP/DOWN
AER
WINDOW – POWER OPERATED, RR DRS, EXPRESS UP/DOWN
AE2
LATCH – REAR COMPARTMENT, SAFETY, MANUAL RELEASE
AFA
INTERIOR TRIM CONFIG – #1
AFB
INTERIOR TRIM CONFIG – #2
AFC
INTERIOR TRIM CONFIG – #3
AFD
INTERIOR TRIM CONFIG – #4
AFE
INTERIOR TRIM CONFIG – #5
AFF
INTERIOR TRIM CONFIG – #6
AFG
INTERIOR TRIM CONFIG – #7
AFH
INTERIOR TRIM CONFIG – #8
AG1
ADJUSTER FRONT SEAT – POWER, MULTI-DIRECTIONAL, DRIVER
AG2
ADJUSTER PASSENGER SEAT – POWER, MULTI-DIRECTIONAL
AHR
RESTRAINT – HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT
AKK
WINDOW STYLE – ACOUSTIC PVB
AKX
WINDSHIELD TYPE – SOLAR ABSORBING
AL0
SENSOR INDICATOR – INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
ANH
RESTRAINT SYSTEM – SEAT, INFLATABLE, DRIVER AND PASS FRT, FRT SEAT SIDE, FRT ROW ROOF SIDE, KNEE
APG
CONTROL – SEAT, POWER LUMBAR, LEFT
APH
CONTROL – SEAT, POWER LUMBAR, RIGHT
AP9
NET – CONVENIENCE
ASV
EQUIPMENT – SENSOR AIR MOISTURE & W/S TEMP
ATH
LOCK CONTROL, ENTRY – REMOTE ENTRY, EXTENDED RANGE, PASSIVE ENTRY, ALL DOORS
AXG
WINDOW – POWER OPERATED – EXPRESS DRIVER UP/DOWN
AXJ
VEHICLE TYPE – PASSENGER CAR
AYF
RESTRAINT SYSTEM – SEAT, INFLATABLE, DRIVER AND PASSENGER FRONT, FRONT SEAT SIDE AND REAR SEAT SIDE, ROOF SIDE, KNEE
A44
MEMORY – SEAT ADJUSTER, MIRROR, POWER, DRIVER/PASS, PERSONALIZATION
A51
SEAT – FRONT BUCKET, CUSTOM
A69
RESTRAINT – SEAT BELT TENSIONER, FRONT, VAR. 2
A70
A90
LOCK CONTROL REAR COMPARTMENT – LID, REMOTE CONTROL ELEC RELEASE
BTM
SWITCH – ENGINE START, KEYLESS
BTT
ALARM – REMOTE PANIC
BTV
REMOTE START – ENGINE
BV6
ORNAMENTATION – EXTR, RR COMPT LID "PLATINUM"
B05
BODY EQUIPMENT – ARMORED
B34
COVERING FRT – FLOOR MATS, CARPETED INSERT
B35
COVERING REAR – FLOOR MATS, CARPETED INSERT
B58
COVERING – FLOOR MAT, FRT AND RR, CARPETED INSERT
B85
MOLDING B/S – EXTERIOR, BRIGHT
B9Q
MODEL CONVERSION – HEARSE
CE1
WIPER SYSTEM – WINDSHIELD, PULSE, MOISTURE SENSITIVE
CJ2
HVAC SYSTEM – AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
CJ4
HVAC SYSTEM – AIR CONDITIONING, FRT AND RR ELECTRONIC CONTROLS
C3U
ROOF – SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED
C59
VENT – AIR, CONSOLE, RR
DA2
ARM REST – RR SEAT, STORAGE, PASS THROUGH
DBU
CONSOLE – FRT COMPT, FLOOR, ARM REST SLIDING
DB3
SUNSHADE – RR WINDOW, ELECTRIC
DCP
PROCESSING – DIRECTIONS AND CONNECTIONS SERVICE PACKAGE
DD8
MIRROR INSIDE REARVIEW – LIGHT SENSITIVE
DE8
SUNSHADE – WINDOW, RR SIDE
DH6
MIRROR INSIDE FRONT VANITY – LEFT AND RIGHT, SUNSHADE, ILLUM
DT4
ASHTRAY – CIGARETTE LIGHTER
DWK
MIRROR O/S – LH AND RH, RC, ELEC, HEAT, FLAT/DRVR, MANFOLD, CNVX/PASS, TURN SIG IND
DWL
MIRROR O/S – LH AND RH, RC, ELEC, HEAT, FLAT/DRVR, MANFOLD, CNVX/PASS, TURN SIG IND, LT SENS
D70
RATIO – TRANSAXLE FINAL DRIVE 2.77
EA1
POCKET – FRONT SEAT BACK, LEFT
EA2
POCKET – FRONT SEAT BACK, RIGHT
EAL
TRIM SEAT – LEATHER, SOLEIL KEISEL, MINI PERF
EF7
COUNTRY – UNITED STATES OF AMERICA (USA)
ESL
TRIM SEAT – LEATHER, OPUS MINI PERF
FE9
CERTIFICATION – EMISSION, FEDERAL
FHO
VEHICLE FUEL – GASOLINE E10
FKV
TRIM DOOR – PVC, CORINTHIAN MINI PERF
FKW
TRIM DOOR – LEATHER, PROVENCE
FKZ
TRIM DOOR – PUR, SHEFFIELD
FLA
TRIM DOOR – PUR, SHEFFIELD, VAR 1
FLB
TRIM DOOR – PVC, CORINTHIAN MINI PERF, VAR 1
FX3
RIDE AND HANDLING – AUTOMATIC ELECTRONIC CONTROLLED
F38
CHASSIS – REAR, AIR, INCREASED RIDE
F46
CHASSIS – ALL WHEEL DRIVE (AWD)
F55
CHASSIS – CONTINUOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL
GAN
PRIMARY COLOR – EXTERIOR, SWITCHBLADE SILVER MET (G) 636R
GAZ
PRIMARY COLOR – EXTERIOR, SUMMIT WHITE (G) 8624
GBA
PRIMARY COLOR – EXTERIOR, BLACK (G) 8555
GBE
PRIMARY COLOR – EXTERIOR, CRYSTAL CLARET TINTCOAT (G) 505Q
GBN
PRIMARY COLOR – EXTERIOR, WHITE DIAMOND TRICOAT (G) 800J
GGC
GRILLE – CUSTOM
GKP
PRIMARY COLOR – EXTERIOR, MARY KAY PEARL TRI-COAT V (590Q)
GLJ
PRIMARY COLOR – EXTERIOR, ASHEN GRAY METALLIC 810T
GLK
PRIMARY COLOR – EXTERIOR, BLACK DIAMOND TRICOAT 815T
GNA
CHASSIS EQUIPMENT FRONT – STRUT ASM
GNB
CHASSIS EQUIP FRONT – STRUT ASM, PERFORMANCE
GNE
CHASSIS EQUIP REAR – REAR AXLE, H-ARM
GWT
PRIMARY COLOR – EXTERIOR, CHAMPAGNE SILVER MET (102V)
GW5
RATIO – TRANSAXLE FINAL DRIVE 3.16
GXH
PRIMARY COLOR – BERLIN BLUE MET (122V)
G96
AXLE POSITRACTION – LIMITED SLIP, ELECTRONIC
HD7
HANDLE – O/S, DR, ILLUMINATED
IO5
RADIO – INFOTAINMENT SYSTEM – UPLEVEL WITH CONNECTIVITY
IO6
RADIO – INFOTAINMENT SYSTEM – UPLEVEL WITH CONNECTIVITY AND EMBEDDED NAVIGATION
I14
ENGINEERING YEAR – 2014
J55
BRAKE SYSTEM – HEAVY DUTY
J6C
CALIPER COLOR – SILVER
J64
BRAKE SYSTEM – POWER, FRT AND RR DISC, ABS, 18+
J71
BRAKE PARKING – POWER OPERATED
KA1
HEATER SEAT FRT – DRVR AND PASS
KA6
HEATER SEAT – REAR
KB7
CONTROL – MANUAL SHIFT, AUTOMATIC TRANSMISSION
KD4
RECEPTACLE – ELECTRICAL, FRONT CONSOLE
KEH
KNOB – TRANS CONT LEVER, UPLEVEL
KI6
RECEPTACLE – ELECTRICAL, FRT CONSOLE RR 110 VOLT
KPA
KRV
REFRIGERANT – LOW GWP
KSG
CRUISE CONTROL – AUTOMATIC, ADAPTIVE, WITH STOP/GO
KTI
KIT, TIRE – INFLATOR
KU1
VENTILATED SEAT DRVR – FRONT
KU3
VENTILATED SEAT PASS – FRONT
KW5
GENERATOR – 220 AMP
KW7
GENERATOR – 170 AMP
K05
HEATER ENG – BLOCK
K34
CRUISE CONTROL – AUTOMATIC, ELECTRONIC
K4T
BATTERY – LN3, FLA, 12V, 80AH, 660 SAE
LFX
ENGINE – GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM, GM
LF3
ENGINE – GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, ALUM, TWIN TURBO, GM
LHD
VEHICLE DRIVE – LEFTHAND DRIVE
MHM
TRANSMISSION – AUTO 6 SPD, HMD, 6T80, AWD, GEN 2
MWN
TAILPIPE – DUAL, INTEGRATED IN FASCIA
M7U
TRANSMISSION – AUTO 6 SPD, 6T70, AWD, GEN 2
M7V
TRANSMISSION – AUTO 6 SPD, 6T75, FWD, GEN 2
M7W
TRANSMISSION – AUTO 6 SPD, 6T70, FWD, GEN 2
NCG
LOCK – ELECTRICAL CHILD LOCK SYSTEM (REAR DOOR LATCH)
NE1
CERTIFICATION – EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14,000 LBS GVW (USE 2003 MDL YR)
NJ2
STEERING – ELECTRIC, BELT DRIVE
NKC
NOISE CONTROL – SYSTEM, ACTIVE NOISE CANCELLATION
NKD
NOISE CONTROL – ENGINE SOUND ENHANCEMENT
NR5
STEERING WHEEL – LEATHER, 4 SPOKES, DELUXE
NR7
STEERING WHEEL – LEATHER WRAPPED, HEATED (DO NOT USE AFTER 2012 M.Y.)
NT7
EMISSION SYSTEM – FEDERAL, TIER 2
NU5
EMISSION SYSTEM – CALIFORNIA, BIN 4
NU6
EMISSION SYSTEM – CALIFORNIA, PZEV
NWT
TAILPIPE – DUAL, TURNED DOWN. HIDDEN
NXC
STEERING – POWER, VARIABLE EFFORT, REDUCED RACK TRAVEL
N38
STEERING COLUMN – TILT, TELESCOPING, POWER
OSH
PLANT CODE – OSHAWA 1, ONT, CANADA
PMA
CONTROL – SEAT, MANUAL CUSHION EXTN, LH
PMB
CONTROL – SEAT, MANUAL CUSHION EXTN, RH
Q2B
TIRE ALL – P245/45R19 SL 98V BW AL3
Q6M
WHEEL – 19 X 8.5, J, ALUMINUM, DESIGN 2
RAL
TIRE ALL – P245/40R20 SL 95V BW AL3
RGS
TIRE ALL – 235/55R18 XL 104H BW ALS
RQ9
WHEEL – 20 X 8.5, J, ALUMINUM, DESIGN 1
RQA
WHEEL – 20 X 8.5, J, ALUMINUM, DESIGN 2
RT9
WHEEL – 19 X 8.5, J, ALUMINUM, DESIGN 1
RVN
WHEEL SPARE – 18 X 4.0, T, ALUMINUM, DESIGN 1
RV1
WHEEL – 18 X 8.0, J, ALUMINUM, DESIGN 3
RWS
ACCESSORY – FLOOR MATS – CARPET
RWU
ACCESSORY – CARGO AREA ORGANIZER – COLLAPSIBLE
SAO
ACCESSORY – SMOKERS PACKAGE
SFE
ACCESSORY – WHEEL LOCKS
S08
ACCESSORY – HIGHWAY SAFETY KIT
S2J
WHEEL SPARE – 18 X 8.0, J, ALUMINUM, DESIGN 3
S40
ACCESSORY – LINER – TRUNK/CARGO AREA
TG5
PLAYER – COMPACT DISC AND MP3
TL1
GRILLE – SPECIAL
TQ5
HEADLAMP HIGH BEAM – AUTO CONTROL
TR7
CONTROL, HEADLAMPS – LEVELING SYSTEM, AUTOMATIC
TSP
LAMP PACKAGE – INTERIOR, CUSTOM
TS6
LAMP – STOP, HIGH LEVEL
TU2
LAMP – MARKER, SIDE
T4F
HEADLAMPS – HIGH INTENSITY DISCHARGE
T61
LAMP SYSTEM – DAYTIME RUNNING
T83
HEADLAMPS CONTROL – AUTOMATIC ON-OFF
T95
CONTROL, HEADLAMPS – BEAM, DIRECTIONAL (AFL)
UDD
DISPLAY INSTRUMENT – DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC)
UDT
INFOTAINMENT DISPLAY – COLOR INFO DISPLAY (CID) 8", WVGA, TOUCH SCREEN
UDV
DISPLAY INSTRUMENT – DRIVER INFO ENHANCED, FULL CLUSTER (MULTI COLOR GRAPHIC)
UD5
PARK ASSIST – FRONT AND REAR
UD7
SENSOR INDICATOR – REAR PARKING ASSIST
UEC
SENSOR INDICATOR – AUTOMATIC AIR RECIRCULATION
UEU
SENSOR INDICATOR – FORWARD COLLISION ALERT
UE1
COMMUNICATION SYSTEM – VEHICLE, GPS 1
UFG
SENSOR INDICATOR – REAR CROSS TRAFFIC ALERT
UFL
SENSOR INDICATOR – LANE DEPARTURE WARNING
UFQ
PARK ASSIST – FRONT, REAR, LATERAL-FRONT (SEMIAUTOMATIC STEERING ADVANCED PARKING AID)
UFT
SENSOR INDICATOR – SIDE OBSTACLE DETECTION
UG1
OPENER — GARAGE DOOR, UNIVERSAL
UGN
SENSOR – COLLISION AVOIDANCE AND MITIGATION, VEHICLE FORWARD MOVEMENT, BRAKE PREFILL AND INTELLIGENT BRAKE ASSIST
UH1
INDICATOR – SEAT BELT WARNING, RH
UJM
TIRE PRESSURE INDICATOR – MANUAL LEARN
UMN
SPEEDOMETER – INST, MILES & KILO, MILES ODOMETER
UQA
SPEAKER SYSTEM – PREMIUM AUDIO BRANDED WITH AMPLIFIER
UQG
SPEAKER SYSTEM – ENHANCED AUDIO WITH AMPLIFIER
UQS
SPEAKER SYSTEM – PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER
USR
RECEPTACLE – USB
US3
ANTENNA – DIVERSITY
UTJ
THEFT DETERRENT – ELECTRICAL, UNAUTHORIZED ENTRY
UVC
CAMERA – REAR VIEW
UVD
HEATER – STEERING WHEEL
UVZ
SENSOR – COLLISION AVOIDANCE AND MITIGATION, VEHICLE REVERSE MOVEMENT
UV6
DISPLAY – HEAD UP
UWG
ENTERTAINMENT PKG – RR SEAT, DUAL DISPLAY, REM CONTROL, AUX JACK, 2 WIRELESS DUAL CHANNEL HEADPHONES
U19
SPEEDOMETER – INST, KILO & MILES, KILO ODOMETER
U2M
DIGITAL AUDIO SYSTEM – S-BAND AND HD
U80
DISPLAY – COMPASS
VAV
ACCESSORY – FLOOR MATS – ALL WEATHER
VK3
LICENSE PLATE FRONT – FRT MOUNTING PKG
VLI
ACCESSORY – MAT – TRUNK/CARGO AREA
VUV
ACCESSORY – BRAKE PADS – PERFORMANCE
VXT
VEHICLE TYPE – INCOMPLETE
VYW
ACCESSORY – FLOOR MATS – PREMIUM CARPET – DESIGN 1
VZE
VIN MODEL YEAR – 2014
VZ3
LABEL – MERCURY DISPOSAL NOTIFICATION
V33
TOOL KIT – ROAD, EMERGENCY
V4U
MODEL CONVERSION – LIMOUSINE
V8D
VEHICLE STATEMENT – US
V8E
VEHICLE STATEMENT – CANADA
W1Y
CONTROL – STEERING WHEEL, RADIO, REDUNDANT CONTROLS
W2D
ACCESSORY – CARGO NET
W20
MERCHANDISED PKG – CADILLAC DEVILLE LIVERY
W28
CONTROL – REAR ARMREST, RADIO, REDUNDANT CONTROLS
W30
EQUIPMENT – STRETCH LIVERY
W68
CONTROL – REAR ARMREST, RR/BKLT S/SHADE, REDUNDANT CONTROLS
XFE
FUEL ECONOMY – EXTRA FUEL ECONOMY
XL7
FREQUENCIES RATING – 433 MHZ
XZ1
EQUIPMENT – PACKAGE, HOT WEATHER
YF5
CERTIFICATION – EMISSION, CALIFORNIA
YM8
IDENTIFICATION – LIMITED PERSONALIZATION OPTION (LPO)
ZB2
TIRE SPARE – 235/55R18 XL 104H BW ALS
ZCD
TIRE SPARE – T135/70R18 SL 104M BW SPR
Z49
COUNTRY – CANADA
01A
TRIM COLOR SEAT – JET BLACK VAR 1
01F
TRIM COLOR SEAT – SHALE
01S
TRIM COLOR SEAT – MED TITANIUM
05B
TRIM COLOR SEAT – CARAMEL TAN
05C
TRIM COLOR SEAT – V LT PLATINUM
1AB
TRIM COLOR DR PANEL – JET BLACK
1AR
TRIM COLOR DR PANEL – MED TITANIUM
1BE
TRIM COLOR DR PANEL – COCOA
1CQ
TRIM COLOR DR PANEL – CARAMEL TAN
1CR
TRIM COLOR DR PANEL – V LT PLATINUM
1CS
TRIM COLOR DR PANEL – LT WHEAT
1SA
PACKAGE – OPTION 01
1SB
PACKAGE – OPTION 02
1SC
PACKAGE – OPTION 03
1SD
PACKAGE – OPTION 04
4AA
INTERIOR TRIM – JET BLACK
4AV
INTERIOR TRIM – JET BLACK/MED TITANIUM
4B8
INTERIOR TRIM – COCOA/SHALE
4CW
INTERIOR TRIM – JET BLACK/CARAMEL TAN
4CY
INTERIOR TRIM – DK URBAN/COCOA/V LT PLATINUM
4CZ
INTERIOR TRIM – JET BLACK/LT WHEAT
5A7
WHEEL SPARE – NONE
9H8
LAMP SYSTEM – DAYTIME RUNNING, AUXILIARY
9L3
TIRE SPARE – NONE
Thanks for posting all of the 2014 RPO Codes. Now if I can only find the RPO label on my XTS. I've looked everywhere in the trunk that I can without tearing it totally apart and I still haven't found it. Maybe I should just ask the dealer the next time I take it in to provide me with a copy of the RPO label?
Steve
You have to remove the plastic cover the with rings for for the cargo net. The label is on the the lower left side of the trunk floor.
2016 XTS Premium
Steve
Is this removal/reinstall process tedious or intuitive as to how and remove the plastic cover?
2016 XTS FWD Platinum
They are the option codes that your vehicle was built with. If you post your 17 digit VIN number, I can list your codes for you.
Max
2018 Cadillac XTS Luxury
Max
Max, if you can give me my option code list, I would appreciate it. My VIN is 2G61M5S39J9158652
Thanks for the offer but I would like to find my RPO sticker do you know where they hid it
It is usually somewhere in the trunk, maybe on the underside of the tire cover but it will just give you the codes, not what they are.
Max
No problem! Here you go! It also looks like you have an open recall. Next time you take it in to the dealership, make sure they fix it for you!
Max
Model: 6GC69-2018 XTS LUXURY Order Number: VRVZD0
Gross Vehicle Weight: 2,276 Build Date: 02/19/2018
Build Plant: 9
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
01F - RIM COLOR SEAT SHALE 1AG - TRIM COLOR DR PANEL SHALE
1SB - LUXURY COLLECTION 1SZ - DISCOUNT OPTION PACKAGE
4A5 - INTERIOR TRIM JET BLACK/SHALE6FG - COMPONENT FRT LH COMPUTER SEL SUSP
7FG - COMPONENT FRT RH COMPUTER SEL SUSP 8FB - COMPONENT RR LH COMPUTER SEL SUSP (8FB)
9FB - COMPONENT RR RH COMPUTER SEL SUSP (9FB) 9H8 - DAYTIME RUNNING LAMPS
A45 - MEMORY SETTINGS, DRIVER SEAT, OUTSIDE MIRRORS, POWER RAKE & TELESCOPIC STEERING COLUMN A51 - FRONT BUCKET SEATS
A69 - RESTRAINT SEAT BELT TENSIONER, FRT, VAR. 2 A70 - RESTRAINT SEAT BELT TENSIONER, FRT
A90 - LOCK CONTROL RR CMPT LID, REM CONT ELEC RELEASE AE2 - LATCH RR COMPARTMENT, SAFETY, MANUAL RELEASE
AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN AER - WINDOW POWER OPERATED, RR DRS EXPRESS UP/DOWN
AFD - SHALE / JET BLACK ACCENTSAG1 - ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2 - ADJUSTER PASS ST AHR - RESTRAINT HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT
AKK - WINDSHIELD STYLE ACOUSTIC PVBAKX - WINDSHIELD TYPE SOLAR ABSORBING
AL0 - AIRBAG SENSING SYSTEM, FRONT PASSENGER AP9 - CONVENIENCE NET, TRUNK
APG - PWR SEAT ADJUSTER, DRIVER, 4-WAY LUMBAR APH - PWR SEAT ADJUST, FRONT PASS 4 WAY LUMBAR
ATH - EZ KEY PASSIVE ENTRY SYSTEMAXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN
AXJ - VEHICLE TYPE - PASSENGER CARAYF - AIRBAGS, DRIVER & PASSENGER FRONTAL & SIDE IMPACT HEAD SIDE CURTAIN
B34 - FLOOR �MATS, FRONT B35 - FLOOR MATS, REAR
B85 - BODY SIDE MOLDING, BODY COLORB9E - VEHICLE GM PROD WEEK 05
BTM - KEYLESS START BTT - PANIC ALARM BUTTON
BTV - ADAPTIVE REMOTE STARTC1U - FLT-ENTERPRISE RENT A CAR
C59 - VENT AIR, CONSOLE, RRCE1 - WINDSHIELD WIPERS, RAIN SENSING
CJ2 - AIR CONDITIONING, DUAL ZONE CLIMATE CONTROL D70 - AXLE, 2.77 FINAL DRIVE RATIO
DA2 - ARMREST, REAR PASS THRUDBU - CONSOLE, FRT COMPARTMENT FLOOR, ARM REST SLIDING
DD8 - INSIDE REARVIEW MIRROR, AUTO DIMMING DH6 - MIRROR I/S FRT VAN LH & RH, SUNSHADE, ILLUM
DNV - MIRRORS, OUTSIDE HEATED, POWER ADJUSTABLE, BODY COLOR, AUTO DIMMING, POWER FOLDING EA1 - POCKET FRONT SEAT BACK, LH
EA2 - POCKET FRONT SEAT BACK, RHEAL - SEAT TRIM, SOLEIL KEISEL MINI PERFORATED INSERTS, LEATHER SEATING SURFACES
EF7 - COUNTRY CODE, U.S.A. FE9 - 50-STATE EMISSIONS
FHO - VEHICLE FUEL GASOLINE E10FLA - TRIM DOOR PUR, SHEFFIELD, VAR 1
FLT - FLEET FX3 - STABILITRAK-STABILITY CONTROL SYSTEM W/ TRACTION CONTROL
GMU - BRONZE DUNE METALLIC GNB - SUSPENSION FRONT PERFORMANCE
GNE - SUSPENSION, REAR H ARMHD7 - DOOR HANDLES, ILLUMINATED
I18 - ENGINEERING YEAR 2018IOT - CADILLAC USER EXPERIENCE, 8" DIAGONAL COLOR DISPLAY, ONSTAR CONNECTED NAVIGATION 1 YEAR TRIAL, APPLE CARPLAY & ANDROID AUTO(R) CAPABILITY PROVIDED BY APPLE & GOOGLE, AVAILABLE WITH COMPATIBLE SMARTPHONES
J64 - BRAKES, ANTILOCK 4 WHEEL DISC BREMBO J71 - BRAKE, PARKING
K34 - CRUISE CONTROL K4C - WIRELESS DEVICE CHARGING
K4T - BATTERY, RUNDOWN PROTECTION,KA1 - DRIVER & FRONT PASSENGER HEATED SEATS
KA6 - SEATS, HEATED REAR OUTBOARD POSITIONS KB7 - CONTROL MANUAL SHIFT, AUTOMATIC TRANSMISSION
KD4 - RECEPTACLE ELECTRICAL, FRT CONSOLE KEH - SHIFT LEVER, LEATHER-WRAPPED WITH WOOD
KI3 - HEATED STEERING WHEELKPA - RECEPTACLE ELECTRICAL, FRT CONSOLE RR
KRV - REFRIGERANT LOW GWP KU9 - SEATS, VENTILATED DRIVER AND FRONT PASSENGER
KW7 - GENERATOR LFX - ENGINE, 3.6L SIDI DOHC V6 VVT
LHD - VEHICLE DRIVE LEFTHAND DRIVEM7W - TRANSMISSION, 6-SPEED AUTOMATIC FWD
MAH - MARKETING AREA NORTH AMERICAMCR - RECEPTACLE MEMORY CARD
MM1 - MERCHANDISED TRANS AUTO EQUIPMENTMWN - EXHAUST, DUAL-OUTLET STAINLESS STEEL
N38 - STEERING COLUMN, POWERTILT & TELESCOPIC NCG - LOCK ELECTRICAL CHILD LOCK SYSTEM (REAR DOOR LATCH)
NJ2 - STEERING, POWER, VARIABLE ASSIST, ELECTRIC NKC - NOISE CONTROL SYSTEM, ACTIVE NOISE CANCELLATION
NR7 - STEERING WHEEL, LEATHER WRAP HEATED W/ TAP UP/DOWN CONTROL NTB - EMISSION SYSTEM FEDERAL
OSH - PLANT CODE OSHAWA R6F - B-CODE ASSIGNMENT VOMS
R9N - CONTROL SALES ITEM NO. 89R9Z - CONTROL SALES ITEM NO.100
RJZ - TIRES, ALL-SEASON BLACKWALLRUI - 19" STERLING SILVER PREMIUM PAINTED ALLOY WHEELS
RVN - WHEEL, 18" ALUMINUM SPARET4L - LED HEADLAMPS DISCHARGE
T83 - HEADLAMPS CONTROL AUTOMATIC ON/OFF TB8 - HEADLAMPS CONTROL RH RULE OF THE ROAD
TDM - TEEN DRIVER TL1 - DELUXE GRILL
TS6 - LAMP STOP, HIGH LEVELTSP - LIGHTING
TU2 - LAMP MARKER, SIDE U2M - SIRIUSXM AND HD RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY SEPARATELY BY SIRIUSXM AFTER 3 MONTHS
U80 - DISPLAY COMPASS UDD - DISPLAY, MULTI-COLOR DRIVER INSTRUMENT INFO ENHANCED
UDT - INFOTAINMENT DISPLAY COLOR INFO DISPLAY (CID) 8", WVGA UE1 - ONSTAR(R)
UEC - SENSOR, AUTOMATIC AIR CIRCULATIONUFQ - AUTOMATIC PARKING ASSIST
UG1 - UNIVERSAL HOME REMOTEUH1 - INDICATOR SEAT BELT WARNING, RH
UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE) UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER
UQA - AUDIO SYSTEM- PREMIUMUS3 - ANTENNA DIVERSITY
USS - RECEPTACLE USB CHARGE PORTUTJ - CONTENT THEFT ALARM, THEFT DETERRENT SYSTEM
UVC - REAR VISION CAMERA SYSTEMV33 - TOOLKIT
V8D - VEHICLE STATEMENT US VQ2 - FLEET ORDERING AND ASSISTANCE
VRG - VAA/COMPONENT REL COCKPITVRH - VAA/COMPONENT REL STEERING COLUMN
VRK - VAA/COMPONENT REL ROOF TRIMVRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION
VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION VRN - VAA/COMPONENT REL REAR SUSPENSION
VRR - VAA/COMPONENT REL TIRES & WHEELS VV4 - 4G LTE WI-FI (R) HOTSPOT CAPABLE (SUBJECT TO TERMS SEE ONSTAR.COM)
VX7 - FLT-PURCHASE RISK PROGRAMW1Y - CONTROL STEERING WHEEL, RADIO, REDUNDANT CONTROLS
WGA - COLLECTION RDO EQUIP RECEIVING UNIT, RADIO WMJ - VIN MODEL YEAR 2018
XFE - FUEL ECONOMY EXTRA FUEL ECONOMYXL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE
ZCD - TIRE, COMPACT SPARE * WHEEL, 18" ALUMINUM SPARE * TOOLKIT
1 - 20 of 54 Posts
