1 - 8 of 8 Posts
1997 Caddilac Deville D'elegane
I have a 1997 Cadillac DeVille D'elegance with 114,000 miles on it. I ran the diagnostics through the computer and I have no current codes but the service engine light is on? Any ideas! :hmm:
like Ranger said -
if the SES light came on - there are codes -
try again - using this method -
go here and read the ENTIRE post -
http://www.cadillacforums.com/forums/cadillac-deville-1985-2005-including-1985/138257-how-pull-codes-dtcs.html
post the codes here -
ALONG WITH THEIR DEFINITIONS -
I ran the codes through following the entire post.
Codes:
PCM P1520 History
PCM P1527 History
NO IPC Codes
NO ACM Codes
NO SDM Codes
NO TCS Codes
NO PZM Codes
NO IRC Codes
RFA B2560 History
NO MSM Codes
NO MMM Codes
Since these are not current codes...no reason to post definitions. SES light is still on! What to do!?
Codes:
PCM P1520 History
PCM P1527 History
NO IPC Codes
NO ACM Codes
NO SDM Codes
NO TCS Codes
NO PZM Codes
NO IRC Codes
RFA B2560 History
NO MSM Codes
NO MMM Codes
so - clear the codes and see what happens
2010 DTS
Codes go to history and extinguish the SES light after 3 successful ignition cycles with no fault detected. Since your light was still on we can determine that the fault was recent (within the last 3 ignition cycles). Chances are, those codes may return.
1 - 8 of 8 Posts
