1 - 20 of 24 Posts
You need to know what the problem is before you can fix it.
What year?
Go to the top of the FWD Deville/Fleetwood page, a and read the "sticky" thread on how to pull codes. List any codes you find, AND THEIR DEFINITIONS, here (there's a link within the sticky with code definitions).
If you're getting an air bag light/message, you have a related B code. What codes are you getting, current and history?
1998 Cadillac Deville
devillesoill3 said:
I got a couple codes coming up but the SDM B relied codes are B1126 current B1147 history B1148 history
If u dnt have the definitions ill postm for u when I get off work
I'm pretty sure these are your SIR communication fault codes tho. I remember getn them when I installed new modules from a 99 Deville. Can't use different year modules bc they dnt link or talk to each other right
But dnt quote me as to the problem jus yet... Could be an entirely different issue
Discussion Starter · #10 ·
I appreciate the help I'm in the boat gotta work! How else am I going to finance these repairs lol. When I get time ill post the definitions as well I might need a new unit but idk till I do a more thorough search.
DTC B1126 Driver Deployment Loop Open
Circuit Description
When you first turn the ignition switch to the RUN position, the inflatable restraint sensing and diagnostic module (SDM) performs tests to diagnose critical malfunctions within itself. Next the SDM measures Ignition Positive Voltage voltage to make sure it is within its respective normal voltage range. Then the SDM proceeds with the DEPLOYMENT LOOP CONTINUITY test. During the DEPLOYMENT LOOP CONTINUITY test, the SDM measures the voltage difference between DRIVER FRONTAL HIGH and DRIVER FRONTAL LOW.
Conditions for Setting the DTC
• The voltage difference between DRIVER FRONTAL HIGH terminal 10 and DRIVER FRONTAL LOW terminal 9 is more than or equal to 426 millivolts.
• The malfunction must be present for at least 500 milliseconds during one of the following tests:
- DEPLOYMENT LOOP CONTINUITY
- If the malfunction is detected in this test, the RESISTANCE MEASUREMENT test will not be performed.
- CONTINUOUS MONITORING
Action Taken When the DTC Sets
• The SDM sets a Diagnostic Trouble Code.
• The SDM commands the instrument panel cluster (IPC) to turn ON the AIR BAG warning lamp.
Conditions for Clearing the MIL/DTC
• Current DTC
The voltage difference between DRIVER FRONTAL HIGH terminal 10 and DRIVER FRONTAL LOW terminal 9 is less than 426 millivolts for 500 milliseconds.
• History DTC
- You issue a scan tool CLEAR CODES command.
- Once 250 malfunction free ignition cycles have occurred.
Diagnostic Aids
The following can cause an intermittent condition:
• A poor connection at the inflatable restraint steering wheel module column connector terminals A and B.
• A poor connection at the upper inflatable restraint steering wheel coil connector terminals A and B.
• A poor connection at the SDM terminals 10 and 9.
• An open in CKT 347.
• An open in CKT 348.
An intermittent open in the inflatable restraint steering wheel module coil could also set this DTC. To test for a bad inflatable restraint steering wheel module coil, clear the DTCs, then turn the steering wheel back and forth with the ignition switch in the RUN position. If the AIR BAG warning lamp comes ON and DTC B1126 has set again, it is likely the inflatable restraint steering wheel module coil is malfunctioning.
The diagnostic table directs the technician to note the scan tool value of DRIVER VDIF. Comparing the value of DRIVER VDIF can be helpful in determining if an intermittent condition exists.
When measurements are requested in this table, use the J 39200 DMM with the correct terminal adapter from the J 35616 Connector Test Adapter Kit. When an inspection for proper connection is requested, refer to Testing for Electrical Intermittents in Wiring Systems. When a wire, connector or terminal repair is requested, use the J-38125 Terminal Repair Kit and refer to Wiring Repairs in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table:
This test determines the deployment loop voltage difference measured by the inflatable restraint sensing and diagnostic module (SDM).
This test checks for proper contact or corrosion of the yellow 2-way connector.
This test isolates the malfunction to one side of the inflatable restraint steering wheel module coil yellow 2-way connector.
This test determines whether the malfunction is due to the inflatable restraint steering wheel module or the module coil.
This test checks for proper contact or corrosion of the SDM connector.
This test determines whether the malfunction is in CKT 347.
This test determines whether the malfunction is in CKT 348.
DTC B1126 Driver Deployment Loop Open Step
Action
Value(s)
Yes
No
1
Was the SIR Diagnostic System Check performed?
Go to Step 2
Go to SIR Diagnostic System Check
Turn the ignition switch to the OFF position.
Connect a scan tool to the DLC.
Turn the ignition switch to the RUN position.
Request the SIR data list display.
Read and record on the repair order the driver deployment loop voltage difference DRIVER VDIF.
Has the DRIVER VDIF been read and recorded on the repair order?
Go to Step 3
3
Disconnect the inflatable restraint steering wheel and IP module yellow 2-way connectors at the base of the steering column and behind the IP compartment.
Inspect for proper connection at terminals A and B on the harness side of the inflatable restraint steering wheel module yellow 2-way connector.
Are the terminals damaged or corroded?
Go to Step 4
Go to Step 6
4
Replace the inflatable restraint steering wheel module yellow 2-way harness connector. Refer to Wiring Repair .
Are the repairs complete?
Go to Step 5
5
Check for proper connection at terminals A and B on the coil side of the connector.
Go to Step 7
Go to Step 23
6
Go to Step 7
Go to Step 8
7
Replace the inflatable restraint steering wheel module coil. Refer to Inflatable Restraint Steering Wheel Module Coil in Steering.
Go to Step 23
8
Connect the 2-way harness connectors.
Using the scan tool, request the SIR data list display.
Read the driver deployment loop voltage difference DRIVER VDIF.
Is the DRIVER VDIF less than the specified value?
426 mV
Go to Step 9
Go to Step 10
9
Go to Step 23
10
Connect the J 38715-A SIR Driver/Passenger Load Tool at the harness connectors.
426 mV
Go to Step 11
Go to Step 14
11
Remove the inflatable restraint steering wheel module. Refer to Steering.
Disconnect the J 38715-A from the driver yellow 2-way harness connector.
Reconnect the driver yellow 2-way connector.
Connect the J 38715-A to the upper inflatable restraint steering wheel module connector.
Read the driver deployment loop voltage difference VDIF.
426 mV
Go to Step 12
Go to Step 13
12
Replace the inflatable restraint steering wheel module. Refer to Steering.
Go to Step 23
13
Replace the inflatable restraint steering wheel module coil. Refer to Steering.
Go to Step 23
14
Disconnect the inflatable restraint sensing and diagnostic module (SDM).
Disconnect the J 38715-A .
Check for proper connection at terminals 10 and 9 on the harness side of the SDM connector.
Is the connector damaged or corroded?
Go to Step 15
Go to Step 17
15
Replace the SDM harness connector. Refer to Wiring Repair .
Go to Step 16
16
Check for proper connection at terminals 10 and 9 of the SDM.
Go to Step 18
Go to Step 23
17
Go to Step 18
Go to Step 19
18
Replace the inflatable restraint sensing and diagnostic module (SDM). Refer to Inflatable Restraint Sensing and Diagnostic Module Replacement .
Go to Step 23
19
Zero the J 39200 Digital Multimeter (DMM).
Measure the resistance from the SDM harness connector terminal 10 to the inflatable restraint steering wheel module yellow 2-way harness connector terminal A.
Is the resistance reading within the specified values?
0.0-0.5 ohms
Go to Step 21
Go to Step 20
20
Repair the high resistance condition in CKT 347.
Go to Step 23
21
Zero the J 39200 .
Measure the resistance from the SDM harness connector terminal 9 to the inflatable restraint steering wheel module yellow 2-way harness connector terminal B.
0.0-0.5 ohms
Go to Sensing and Diagnostic Module Integrity Check
Go to Step 22
22
Repair the high resistance condition in CKT 348.
Go to Step 23
23
Reconnect all the SIR system components, make sure all the components are properly mounted.
Have all the SIR components been reconnected and properly mounted?
Go to Step 24
24
Clear all the SIR DTCs.
Have all the SIR DTCs been cleared?
DTC B1148 Pass. Side Air Bag System Malfunction
Circuit Description
When you turn the ignition switch to the RUN position, the inflatable restraint Side Impact Sensing Module (SISM) performs tests to diagnose critical malfunctions within itself. The SISM then tests for the following conditions:
• Deployment loop open.
• Deployment loop short to ground
• Deployment loop short to ignition
• Deployment loop resistance high
• Deployment loop resistance low
• Deployment reserve energy failure
The inflatable restraint Side Impact Sensing Module (SISM) transmits a pulse width modulated signal to the inflatable restraint Sensing and Diagnostic Module (SDM) over CKT 2108. A 300 millisecond pulse width with a 50 percent duty cycle is the Normal mode and indicates that the SISM is operating normally and no faults exist. The SISM communicates that it is turning OFF (ignition OFF) by sending a 20 millisecond pulse width modulated signal with a 50 percent duty cycle.
The SDM receives a pulse width signal other than the Normal signal, or no signal at all. The SISM performs tests during POWER-ON tests, CONTINUOUS MONITORING tests, and Asynchronously.
• The SDM sets DTC B1148.
Conditions for Clearing the DTC
• Current DTC
- The SDM receives a Normal signal from the SISM.
- The ignition switch is cycled.
• History DTC:
- 250 malfunction-free ignition cycles occur.
If a side impact deployment occurs the SISM must be replaced. Follow the instructions in the diagnostic table.
Diagnostic Aids
A poor connection can cause an intermittent condition. Check the following for a poor connection:
• The SISM.
• The inflatable restraint side impact inflator module.
• The SDM terminal 14.
• The wire to terminal connections of all circuits going to the SISM.
If you suspect that the SISM may be the cause of the malfunction, you can switch the SISMs in order to verify an internal SISM malfunction.
Test Description
The numbers below refer to step numbers on the diagnostic table.
If the passenger inflatable restraint side impact inflator deployed, B1148 will set.
Components require inspection and possibly replacement after a side impact accident, whether deployment occurred or not.
This test determines if the malfunction is in the inflatable restraint side impact inflator module.
This test checks for an open in CKT 1751.
This test checks for an open in CKT 1139.
This test checks for a short-to-ground in CKT 2104.
This test checks for an open in CKT 2104.
This test checks for a short-to-voltage in CKT 2104.
This test checks for a short-to-voltage in CKT 2103.
This test checks for high resistance or open in CKT 2103.
This test checks for a short-to-ground in CKT 2108.
This test checks for a short-to-voltage in CKT 2108.
This test checks for an open in CKT 2108.
If all wiring and connections are OK, then and only then should the inflatable restraint Side Impact Sensing Module (SISM) be replaced.
DTC B1148 Passenger Side Air Bag System Malfunction Step
Action
Value(s)
Yes
No
1
Go to Step 2
Has the passenger inflatable restraint side impact inflator module deployed?
Go to Step 4
Go to Step 3
3
Inspect the passenger side of the vehicle and the undercarriage for signs of a side impact.
Are there signs of a side impact?
Go to Step 4
Go to Step 5
4
Replace the components and perform the inspections as directed in Repairs and Inspections Required After a Collision .
Has all the repairs and inspections been completed?
Go to Step 43
5
Remove the SIR Fuse from the trunk compartment fuse block.
Remove the RH front door panel. Refer to Door Trim Panels in Doors.
Disconnect the passenger side air bag yellow 2-way connector located 15 cm (6 in ) below the inflatable restraint side impact inflator module.
Inspect the 2-way harness connector for damage and corrosion.
Is the harness connector damaged or corroded?
Go to Step 6
Go to Step 7
6
Replace the passenger side air bag yellow 2-way harness connector. Refer to Wiring Repair .
Is the circuit repair complete?
Go to Step 42
7
Inspect the 2-way the passenger side air bag yellow 2-way connector for damage and corrosion.
Go to Step 10
Go to Step 8
8
Reconnect the passenger side air bag yellow 2-way connector.
Install the SIR Fuse.
Is DTC B1148 current?
Go to Step 9
Go to Step 43
9
Disconnect the passenger side air bag yellow 2-way connector. Connect the J 38715-A SIR Driver/Passenger Load Tool and the appropriate adapter to the 2-way harness connector.
Go to Step 11
Go to Step 10
10
Replace the inflatable restraint side impact inflator module. Refer to Inflatable Restraint Side Impact Module Replacement - Right Side .
Has the inflatable restraint side impact inflator module been replaced?
Go to Step 43
11
Remove the SIR Fuse.
Disconnect the inflatable restraint Side Impact Sensing Module (SISM).
Check for proper connection at the SISM at all terminals of the SISM harness connector.
Are any of the SISM harness connector terminals damaged or corroded?
Go to Step 12
Go to Step 13
12
Replace the SISM harness connector. Refer to Wiring Repair .
Is the repair complete?
Go to Step 43
13
Carefully inspect the SISM connector terminals for damage or corrosion.
Are any of the SISM connector terminals damaged or corroded?
Go to Step 14
Go to Step 15
14
Has the SISM been replaced?
Go to Step 43
15
Measure the resistance from the SISM harness connector terminal C to ground.
Is the resistance within the specified values?
0 - 0.5 ohms
Go to Step 17
Go to Step 16
16
Repair an open condition in CKT 1751 between the SISM and splice S370.
Go to Step 43
17
Measure the resistance from the SISM terminal E to each terminal of the SIR Fuse fuseholder.
0 - 0.5 ohms
Go to Step 19
Go to Step 18
18
Repair an open condition in CKT 1139 between the SISM and splice S319.
Go to Step 43
19
Disconnect the J 38715-A and the adapter from the inflatable restraint side impact inflator module harness connector.
Measure the resistance from the SISM harness connector terminal A to ground.
0 - 0.5 ohms
Go to Step 20
Go to Step 21
20
Repair a short-to-ground condition in CKT 2104.
Go to Step 43
21
Measure the resistance from the SISM terminal A to the inflatable restraint side impact inflator module terminal B.
0 - 0.5 ohms
Go to Step 23
Go to Step 22
22
Repair a high resistance condition in CKT 2104.
Go to Step 43
23
Make sure the SISM and the inflatable restraint side impact inflator module are disconnected.
Measure the voltage from the SISM harness connector terminal A to ground.
Is the voltage more than the specified value?
1 V
Go to Step 24
Go to Step 25
24
Repair a short-to-voltage condition in CKT 2104.
Go to Step 43
25
Measure the voltage from the SISM harness connector terminal B to ground.
1 V
Go to Step 26
Go to Step 27
26
Repair a short-to-voltage condition in CKT 2103.
Go to Step 43
27
Measure the resistance from the SISM terminal B to ground.
0 - 0.5 ohms
Go to Step 28
Go to Step 29
28
Repair a short-to-ground condition in CKT 2103.
Go to Step 43
29
Zero the J 39200 .
Measure the resistance from the SISM harness connector terminal B to the inflatable restraint side impact inflator module harness connector terminal A.
0 - 0.5 ohms
Go to Step 31
Go to Step 30
30
Repair a high resistance or open condition in CKT 2103.
Go to Step 43
31
Measure the resistance from the SISM harness connector terminal D to ground.
Is the resistance more than the specified value?
0 - 0.5 ohms
Go to Step 32
Go to Step 33
32
Repair a short to-ground condition in CKT 2108.
Go to Step 43
33
Measure the voltage from the SISM harness connector terminal D to ground.
1 V
Go to Step 34
Go to Step 35
34
Repair a short-to-voltage condition in CKT 2108.
Go to Step 43
35
Disable the Frontal SIR system. Refer to Disabling the SIR System .
Check for proper connection of terminal 14 of the SDM harness connector.
Is terminal 14 of the SDM harness connector damaged or corroded?
Go to Step 36
Go to Step 37
36
Go to Step 43
37
Carefully inspect SDM terminal 14 for damage or corrosion.
Go to Step 38
Go to Step 39
38
Replace the SDM. Refer to Inflatable Restraint Sensing and Diagnostic Module Replacement .
Has the SDM been replaced?
Go to Step 43
39
Measure the resistance from the SDM terminal 14 to the SISM harness connector terminal D.
0 - 0.5 ohms
Go to Step 41
Go to Step 40
40
Repair a high resistance or open condition in CKT 2108.
Go to Step 43
41
Replace the SISM Refer to Inflatable Restraint Side Impact Sensing and Diagnostic Module Replacement - Left Side .
Go to Step 42
42
Reconnect all the SIR System components. make sure all the components are properly mounted.
Staying well away from all of the inflator modules, turn the ignition switch to the RUN position.
Is B1148 current?
43
Reconnect all the SIR System components. Make sure all the components are properly mounted.
Have all the SIR System components been properly mounted?
DTC B1147 Driver Side Air Bag System Malfunction
Circuit Description
The inflatable restraint Side Impact Sensing Module (SISM) transmits a pulse width modulated signal to the inflatable restraint Sensing and Diagnostic Module (SDM) over CKT 2107. A 300 millisecond pulse width with a 50 percent duty cycle is the Normal mode and indicates that the SISM is operating normally and no faults exist. The SISM communicates that it is turning OFF (ignition OFF) by sending a 20 millisecond pulse width modulated signal with a 50 percent duty cycle.
• The SDM sets DTC B1147.
• Current DTC
• History DTC:
Diagnostic Aids
• The SISM.
• The SDM terminal 13.
Test Description
If the driver inflatable restraint side impact inflator deployed, B1147 will set.
This test checks for a short-to-ground in CKT 2106.
This test checks for an open in CKT 2106.
This test checks for a short-to-voltage in CKT 2106.
This test checks for a short-to-voltage in CKT 2105.
This test checks for high resistance or open in CKT 2105.
This test checks for a short-to-ground in CKT 2107.
This test checks for a short to voltage in CKT 2107.
This test checks for an open in CKT 2107.
DTC B1147 Driver Side Air Bag System Malfunction Step
Action
Value(s)
Yes
No
1
Go to Step 2
Has the driver inflatable restraint side impact inflator module deployed?
Go to Step 4
Go to Step 3
3
Inspect the driver side of the vehicle and the undercarriage for signs of a side impact.
Go to Step 4
Go to Step 5
4
Go to Step 43
5
Remove the LH front door panel. Refer to Door Trim Panels in Doors.
Disconnect the driver side air bag yellow 2-way connector located 15 cm (6 in ) below the inflatable restraint side impact inflator module.
Go to Step 6
Go to Step 7
6
Replace the driver side air bag yellow 2-way harness connector. Refer to Wiring Repair .
Go to Step 42
7
Inspect the 2-way the driver side air bag yellow 2-way connector for damage and corrosion.
Go to Step 10
Go to Step 8
8
Reconnect the driver side air bag yellow 2-way connector.
Is DTC B1147 current?
Go to Step 9
Go to Step 43
9
Disconnect the driver side air bag yellow 2-way connector. Connect the J 38715-A SIR Driver/Passenger Load Tool and the appropriate adapter to the 2-way harness connector.
Go to Step 11
Go to Step 10
10
Replace the inflatable restraint side impact inflator module. Refer to Inflatable Restraint Side Impact Module Replacement - Left Side .
Go to Step 43
11
Go to Step 12
Go to Step 13
12
Go to Step 43
13
Go to Step 14
Go to Step 15
14
Go to Step 43
15
0 - 0.5 ohms
Go to Step 17
Go to Step 16
16
Go to Step 43
17
0 - 0.5 ohms
Go to Step 19
Go to Step 18
18
Go to Step 43
19
0 - 0.5 ohms
Go to Step 20
Go to Step 21
20
Repair a short-to-ground condition in CKT 2106.
Go to Step 43
21
0 - 0.5 ohms
Go to Step 23
Go to Step 22
22
Repair a high resistance condition in CKT 2106.
Go to Step 43
23
1 V
Go to Step 24
Go to Step 25
24
Repair a short-to-voltage condition in CKT 2106.
Go to Step 43
25
1 V
Go to Step 26
Go to Step 27
26
Repair a short-to-voltage condition in CKT 2105.
Go to Step 43
27
0 - 0.5 ohms
Go to Step 28
Go to Step 29
28
Repair a short-to-ground condition in CKT 2105.
Go to Step 43
29
Zero the J 39200 .
0 - 0.5 ohms
Go to Step 31
Go to Step 30
30
Repair a high resistance or open condition in CKT 2105.
Go to Step 43
31
0 - 0.5 ohms
Go to Step 32
Go to Step 33
32
Repair a short to-ground condition in CKT 2107.
Go to Step 43
33
1 V
Go to Step 34
Go to Step 35
34
Repair a short-to-voltage condition in CKT 2107.
Go to Step 43
35
Check for proper connection of terminal 13 of the SDM harness connector.
Is terminal 13 of the SDM harness connector damaged or corroded?
Go to Step 36
Go to Step 37
36
Go to Step 43
37
Carefully inspect SDM terminal 13 for damage or corrosion.
Go to Step 38
Go to Step 39
38
Go to Step 43
39
Measure the resistance from the SDM terminal 13 to the SISM harness connector terminal D.
0 - 0.5 ohms
Go to Step 41
Go to Step 40
40
Repair a high resistance or open condition in CKT 2107.
Go to Step 43
41
Go to Step 42
42
Is B1147 current?
43
Sorry for the multi post... It wouldnt let me put all that in one post
Circuit Description
• Current DTC
• History DTC:
Diagnostic Aids
• The SISM.
Test Description
Action
Value(s)
Yes
No
1
Go to Step 2
Go to Step 4
Go to Step 3
3
Go to Step 4
Go to Step 5
4
Go to Step 43
5
Go to Step 6
Go to Step 7
6
Go to Step 42
7
Go to Step 10
Go to Step 8
8
Go to Step 9
Go to Step 43
9
Go to Step 11
Go to Step 10
10
Go to Step 43
11
Go to Step 12
Go to Step 13
12
Go to Step 43
13
Go to Step 14
Go to Step 15
14
Go to Step 43
15
0 - 0.5 ohms
Go to Step 17
Go to Step 16
16
Go to Step 43
17
0 - 0.5 ohms
Go to Step 19
Go to Step 18
18
Go to Step 43
19
0 - 0.5 ohms
Go to Step 20
Go to Step 21
20
Go to Step 43
21
0 - 0.5 ohms
Go to Step 23
Go to Step 22
22
Go to Step 43
23
1 V
Go to Step 24
Go to Step 25
24
Go to Step 43
25
1 V
Go to Step 26
Go to Step 27
26
Go to Step 43
27
0 - 0.5 ohms
Go to Step 28
Go to Step 29
28
Go to Step 43
29
Zero the J 39200 .
0 - 0.5 ohms
Go to Step 31
Go to Step 30
30
Go to Step 43
31
0 - 0.5 ohms
Go to Step 32
Go to Step 33
32
Go to Step 43
33
1 V
Go to Step 34
Go to Step 35
34
Go to Step 43
35
Go to Step 36
Go to Step 37
36
Go to Step 43
37
Go to Step 38
Go to Step 39
38
Go to Step 43
39
0 - 0.5 ohms
Go to Step 41
Go to Step 40
40
Go to Step 43
41
Go to Step 42
42
Is B1147 current?
43
do you realize ALL that stuff you pasted in here is TOTALLY USELESS?
do you realize all that stuff you pasted in here is totally useless?
i was initially jus gonna post the code and definition but thought if he could jus get all the info the srvice manual had and let him decide what is usefull and what is not....
Sorry.... Caps stuck on again
here is what makes this useless - look at the first step -
1 Was the SIR Diagnostic System Check performed?
YES - Go to Step 2
NO - Go to SIR Diagnostic System Check
do you think the OP knows HOW to do a SIR Diagnostic System Check -
you can't even go to the second step without performing the check -
and if he simply skips over that part -
2 Turn the ignition switch to the OFF position.
do you suppose the OP has a scan tool?
YES - Go to Step 2
Well he has the codes and definitions
Scantool he can go to a Advance or Napa and rent one... or buy one off ebay... http://www.ebay.com/sch/i.html?_odk...=p2045573.m570.l1313&_nkw=gm+scanner&_sacat=0 ... if he's serious about doing the work himself... http://www.ebay.com/sch/i.html?_odk...3.m570.l1313&_nkw=gm+tech+II+scanner&_sacat=0
no - actually Advance - Napa - Autozone etc -
have CODE READERS -
the TechII is a SCAN TOOL
next time - simply recommend going to the HOW TO PULL CODES STICKY -
http://www.cadillacforums.com/forum...ldorado-forum/138258-how-pull-codes-dtcs.html
or recommend this site for complete code definitions -
http://myweb.accessus.net/~090/dtcobd2.html
have CODE READERS -
http://www.cadillacforums.com/forums/cadillac-seville-cadillac-eldorado-forum/138258-how-pull-codes-dtcs.html
Ah!!!
That's a good idea too!
Next time Ill remember to not post the entire service manual but atleast I got the codes and definitions... Can't I get Some Good Credit Here.
1 - 20 of 24 Posts
