I'm having some issues with the self leveling suspension of my 01 Deville. The diagnosis is showing code #C0660 - Exhaust Pump something.
I noticed the maxifuse for the system was blown. I checked under the car for obvious electrical problems - frayed wiring, disconnected grounds, etc. but could not find anything. I replaced the fuse only to have it blow again the second I started the car.
Is there any common things to look out for when fixing these systems?
I have never heard of that type of problem - usually the air-ride systems have problems on the pneumatic side like leaking air lines or such. If you can get to it I would disconnect the compressor electical connector and see if the fuse still blows. At that point I would start to suspect the compressor has gone south and begin searching jukyards.
2010 DTS
C0660 - Level Control Exhaust Valve Circuit Malfunction
I think the exhaust valve is serviceable separately.
Discussion Starter · #4 ·
I'll have to check the Helm manual when it comes in.
The SLS system is not all that important to me, but it sure helps when I have 6 people in the car, and am going down some nasty class B farm roads.
