the LCD information areas in the instrument panel is called the DIC (Driver Information Center)
the R2D2 looking dome on the dashboard is your automatic headlight sensor and is called the 'Twilight Sentinel'
a double push forward on the headlight stalk enables the automatic high beams
one click up on the wiper stalk enables the auto wipers
if you look at the back seat from the open trunk you will see a lock for the passthrough to lock it for valet purposes
if you unclick the visor and rotate it to the side window you can slide it back and forth on its rod to position it nicely to block the sun...that's what the â—„â–ş on the visors hinge means
the â–ş next to the gas can symbol on the gas gauge points to the side the fuel filler is on
the headlights don't just turn, they are adaptive and use beamforming...that is to say the amount of movement in the beams is not connected to the steering wheel...this is shown by the fact that they do not move when at a standstill no matter how you saw back and forth on the wheel...but as soon as you start rolling and then turn the wheel they move...this is because rather than turn with the wheel the car is using your velocity and the steering angle to calculate your yaw rate and uses the results of this calculation to project light where your car is going to be...the beamforming is the car moves the left and right beams individually and stretches and contracts the beam around bends, so as not to create dark spots mid corner because it pointed the projector elsewhere
the car can park itself in both parallel and perpendicular fashion and in left and right hand parking situations....the 2017 and later versions of CUE have on screen buttons to point this out and control those features, but in earlier (2016 and older) versions of CUE these are a bit of a mystery....after engaging the parking feature, long press the button again to toggle between parallel and perpendicular modes...by default scanning spaces and parking happens on the passenger or right side of the car, but again in pre 2017 CUE use the indicator stalk and click down to turn on the left blinker and the park assist switches scanning as well as the self parking mode to the left or drivers side of the car
touch random things on the CUE screen like the time in the corner or temperature in the other corner for some surprises
in the scrolling station list in CUE you can switch the labels to display station ID, Artist, or Song title
the globe icon in any text input screen turns on handwriting recognition
you can save radio stations, phone numbers, nav destinations, and tone settings in the radio presets...up to 60 of them
you can use the easy exit button in the driver memory as a third preset if you don't use the automated functions like returning to your position at startup or opening up to a comfortable exit position at shutdown
if you put your car into sport or track mode...once the DIC acknowledges you are in one of those modes, if you double tap the traction control button, you will enable a secret car mode called 'Competitive Mode', you'll know you've done this correctly when the DIC says "Stabilitrak Competitive Mode Enabled"
