1 - 15 of 15 Posts
09 CTS-V
Tried doing a search but nothing came up, On my wifes lexus there where codes I could enter to disable the seatbelt reminder. Is there anyway to do this on the V?
Cadillac 2009 CTS-V Radiant Silver
Yes, to stop the chime, and it works great, really great, fasten your seatbelt when you get in.
i be bad
'09 CTS-V, Thunder Gray, Auto
If you unplug the seat belt sensor under the seat, the car thinks the seat belt is always fastened. The chime never sounds again.
It is a two-wire plug that runs to the female end of the seat belt. The plug is attached to the bottom of the seat. It is toward the inside (transmission hump) from the power seat wires/motors.
The wires to the seat belt sensor are easy to spot - they are the only wires headed toward the center of the car. You need to access it from the back seat - put the front seat all the way forward.
No, I am not going to ask why you want to disable your seat belt chime.
09 CTS-V
A+ Appreciate it, Thanks!
11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
it only reminds you twice then it shuts the reminder off. So if you are using aftermarket harnesses, it wont keep bugging you while driving on the road coarse..
09 CTS-V
I found this plug but i can only get one hand in there, How do you pull these apart??
The plug has a clip that holds the two sides together (like most automotive electrical connectors). It is hard to see the clip under the seat, but you need to see where the clip is on the connector (I think it is the bottom of the female side).
A small flat-blade screwdriver will lift the clip so the two sides of the plug will come apart. Push the screwdriver under the clip and leave the screwdriver there holding the clip in the released position. This can be done with one hand.
One side of the plug (female) is tightly wrapped in the wiring harness close to the power seat motors. If you can release the clip, you can just pull on the other side (male/seat belt side) with one hand.
Good luck.
09 CTS-V
Discussion Starter #11
LOW ET WOW, Thanks for going the extra mile, I appreciate the pics. What made this easier was getting the cable off the clip so I could pull it back for better access like LOW ET said. Thanks Again!
Premium Member
2009 CTS-V Black/Black, manual
I think W4M nailed it because that's how mine worked. I'd get warning chimes the first couple of times I drove without the safety belt fastened, but after that, no more chimes. The safety belt light still flashes for a couple of minutes and then goes out, but no more chimes.
Rob
2009 CTS-V, 2009 535i
Just be aware that big brother won't let Dawimism take its course and mandates that the airbag discharge more forcefully if the seat belt isn't fastened. Since I always wear my belt, I prefer the pull the sensor cable method so the system always thinks I'm belted in and I don't get those annoying chimes as I'm starting up.
1 - 15 of 15 Posts
