1 - 2 of 2 Posts
03 cadillac escalade
Ok since I finely have a tech-2 I figured I would set in on fixing my seat issues(one I have figured out)
Ok I am getting
B0041 driver side deployment loop open
Now I know this means it's a open circuit
But here is the weird part
I can disconnect the side air bag(not sure if there is two connectors or just one yet as I haven't fully looked yet) but the code remains
So that tells me it's not seeing the air bag(not good)
Has anyone else had this issue?
If so is a harness replacement the only fix or was it something else??
My other issue is what sfx group had(seat position sensor) which is reading in the -5000 range for some weird reason(likely sensor or track needing cleaning)
Discussion Starter · #2 ·
I have found the problem with the air bag
Now I need to splice the wire back together(not sure on the best way to do that)
The seat position sensor issue was the counts in the seat module after working the control for the forward/aft in the forward position multiple times I got it fixed now it works normally
Any ideas on splicing the air bag wire?
1 - 2 of 2 Posts
