Boost and backpressure have nothing to do with each other. Something else is going on, like a hose isn't plugged in to the right place.
Exactly. This is well documented in the Scooby world.(Subaru)common misnomer.... boost is best when numbers are high...
boost is a measure of how much air is backed up in the intake manifold before the cylinders, if you let the cylinders breath better you'll have less backed up air, hence less boost
so yes, headers will result in a drop in boost, as they free up the "exhale" process.
Long tubes change the flow characteristics of the engine dramatically. Your AFRs are probably really rich if you haven't been tuned since the headers.
Rick at StealthV supposedly has an awesome tune for Maggied cars with headers. I'm not maggied, but his NA tune I'm running is fantastic. If you haven't been dyno tuned since the LTs, I'd recommend sending him an email.
Actually, let me rethink this. Would this apply to superchargers? Exhaust would be dependent on engine THROUGHPUT(capitalized because I like the word). So would boost drop happen? On a turbo, it depends on exhaust gases to run so it's all intertwined. Increased efficiency anywhere in the system would cause a drop in pressure to create the same power.common misnomer.... boost is best when numbers are high...
You are so frickin' brilliant!:highfive:OK - I'm going to ignore the responses and report only cold, hard, personal experience.
Maggie with 3" pulley = 4.5# boost
Maggie with 2.8" pulley = ~7 psi boost
Maggie with 2.6" pulley = 9.5 psi boost (consistent 9's with data logged 9.5's, even a 10 psi once...whoops)
Reference above is stock exhaust with RT cats and gutted mufflers.
Change that to BB 3" exhaust (cat back) and BB original headers (cats blown out)..
Maggie 3" = :wtf: why would I try that again?
Maggie 2.8" = 6.1 psi (highest peak ever)
Maggie 2.6" = 8 psi
So, in reality, measured boost, as with a gauge or data logging device, will be lower.
However - the question you meant to ask is whether CYLINDER PRESSURE remains constant :thepan:
WW
Once again, WW rules... :worship:However - the question you meant to ask is whether CYLINDER PRESSURE remains constant :thepan:
WW
