Maybe a better description would help 'cause you sound like you are contradicting yourself. First off, pads and rotors wear - eventually both need replacing but not necessarily at the same rate.
What does "indent" mean? If you have a 1/2" groove in your rotor where the pads grip then you've lost that much contact area.
You can replace the pads only but if I read your first paragraph right, one of your rear rotors is damaged. Don't you have wear sensors for your dash warning?
