heres my rpo tag
Name
Hydra-matic 4L60-E
RPO Codes
M30, M32
Production Location
Toledo, Ohio
Romulus, MI
Vehicle Platform, Engine/Transmission, Usage
C/K 800
Transmission Drive
Longitudinally-Mounted Rear Wheel Drive
1st Gear Ratio
3.059:1
2nd Gear Ratio
1.625:1
3rd Gear Ratio
1.000:1
4th Gear Ratio
0.696:1
Reverse
2.294:1
Torque Converter Size, Diameter of Torque Converter Turbine
300 mm
Pressure Taps
Line Pressure
Transmission Fluid Type
DEXRON® III
Transmission Fluid Capacity, Approximate
300 mm Converter
Dry: 11.50 l (12.1 qt)
Transmission Type: 4
Four Forward Gears
Transmission Type: L
Longitudinal Mount
Transmission Type: 60
Product Series
Transmission Type: E
Electronic Controls
Position Quadrant
P, R, N, Overdrive, D, 2, 1
P, R, N, Overdrive, 3, 2, 1
Case Material
Die Cast Aluminum
Transmission Weight Dry, Approximate
300 mm Converter
86.17 kg (190.5 lb)
Transmission Weight Wet, Approximate
300 mm Converter
98.4 kg (218.0 lb)
Maximum Trailer Towing Capacity
6 130 kg (13,500 lb)
